compressor
Forum topic by Joseph Jossem posted 10-31-2014 10:44 PM 1199 views 0 times favorited 7 replies Add to Favorites Watch
View Joseph Jossem's profile
Joseph Jossem
492 posts in 2510 days
10-31-2014 10:44 PM
I have a 80 gallon stand up compressor. the line coming from the pump head to the tank has a valve that is adjustable any one know does that adjust the pressure build up settings? ill try to get a picture up asap.thanks for any help.
7 replies so far
View okwoodshop's profile
okwoodshop
448 posts in 3416 days
#1 posted 10-31-2014 11:48 PM
would it be a check valve, or one way valve to keep the air from going back out the way it came in?
View sawdust703's profile
sawdust703
270 posts in 1661 days
#2 posted 11-02-2014 09:16 PM
Does that valve have a gauge on it? If not, that valve is most likely your pop off valve. I’d leave it be were i you. Just my two cents.
-- Sawdust703
View Targa's profile
Targa
118 posts in 1981 days
#3 posted 11-02-2014 09:44 PM
I believe usually any adjustment on a compressor is in the pressure switch to set the pressure at which the compressor turns on and off.
Can you add a picture of it.
-- Dom
View bigblockyeti's profile
bigblockyeti
5322 posts in 1962 days
#4 posted 12-02-2014 01:12 PM
Typically the only valve between the head and receiver is a check valve so the pressure switch can evacuate the pressure from the line to allow for easier startups. Do you have a picture?
View Tennessee's profile
Tennessee
2893 posts in 2756 days
#5 posted 12-02-2014 01:44 PM
The pop-off can actually be anywhere in the system that sees full pressure. Some are on the tanks. I’d say the valve is a check to prevent bleed back from the tank when the piston gets evacuated by the shutoff for easy startups next time. I would not touch it.
View timbertailor's profile
timbertailor
1594 posts in 1665 days
#6 posted 12-02-2014 03:38 PM
- Targa
+1
View lndfilwiz's profile
lndfilwiz
108 posts in 1842 days
#7 posted 12-02-2014 04:48 PM
- Targa
+2
Bigblockyeti is correct.
-- Smile, it makes people wander what you are up to.
