Newly completed Maloof style rocker. Made of Argentine Mesquite, which is two and a half times stronger than Oak. It takes a finish almost as good as glass.
This is a standard style with vertical boards in the Headrest in place of one horizontal board.
This is a text rocker, where I used several small boards where I would usually use one board. Example is the Arm rest that is normally one board whereas on this rocker I spliced two boards together. My wife liked it and the rocker turned out much better than I expected. Showing that one can save cost by using scrap lumber to good advantage.
Get your Free Text on how to make these rockers.
See more pictures at kappelusa.com
