What would be the easiest way to make these?
Forum topic by Micah Muzny posted 10-31-2014 03:13 AM 1590 views 5 times favorited 17 replies Add to Favorites Watch
View Micah Muzny's profile
Micah Muzny
185 posts in 1726 days
10-31-2014 03:13 AM
I found this picture while browsing the web. They don’t look to hard to make but not sure which would be the easiest method. What kind of jig could I make for table saw, miter saw, or bandsaw? I have a dual compound sliding miter saw if there is a way I could tilt it and slide it to cut it at that angle. Perhaps some kind of tapered table saw sled?
17 replies so far
View ChuckC's profile
ChuckC
828 posts in 2928 days
#1 posted 10-31-2014 03:18 AM
Start with square stock cut extra long. Rip each side on a TS using a taper jig and the blade at 45*. After all 4 sides are cut cross-cut to height.
View wseand's profile
wseand
2796 posts in 3035 days
#2 posted 10-31-2014 03:25 AM
Buying those ones. Ah, truly I can’t think of any way right now. They caught my eye though too for some reason. I guess they look like the Washington Monument. I will keep an eye on it to see if anyone else has an idea.
View Yonak's profile
Yonak
986 posts in 1514 days
#3 posted 10-31-2014 04:38 AM
I agree with Chuck except, instead of setting the table saw blade to 45°, I’d make a jig that cuts the taper and lets the pieces rest at 45° to the table top and leave the blade set at 90°. It just seems to me that it would make it easier to tell just where the blade will be cutting, so you come out right at the corner.
wseand
#4 posted 10-31-2014 04:58 AM
They seem to be a bit sharper angle then 45 but it is hard to tell.
View ddockstader's profile
ddockstader
155 posts in 3255 days
#5 posted 10-31-2014 02:17 PM
I believe they are at a 45 degree angle. They are square on top and square at the bottom, only rotated by 45 degrees. A simple V-jig combined with a tapering jig should do it.
View jmartel's profile
jmartel
7877 posts in 2143 days
#6 posted 10-31-2014 03:14 PM
Honestly, I’d use a bandsaw. Those are pretty small pieces to be cutting on the tablesaw. I think trying to cut those on a TS is asking for trouble.
View RRBOU's profile
RRBOU
176 posts in 2285 days
#7 posted 10-31-2014 03:54 PM
Maybe I am wrong but they look to not be made from a solid block. It looks like two different pieces of wood and glued up.
I like it and when I get a chance I think I will attempt to make some. I will be using the band saw. Cut the pieces over size then make a sled to support and adjust the angles and run them through the sander or the planer. They look like a wood eater as to be safe the pieces would need to start out at about 9” long then cut down to whatever you need for the final assembly.
-- If guns cause crime all of mine are defective Randy
View bondogaposis's profile
bondogaposis
4717 posts in 2344 days
#8 posted 10-31-2014 04:01 PM
To make just a few I would use a handsaw. For a production run then a tapering jig on the bandsaw is the way I would do that.
-- Bondo Gaposis
View Blackie_'s profile
Blackie_
4883 posts in 2506 days
#9 posted 10-31-2014 04:34 PM
I’d think a jointer would work as well, I’ve tapered table legs on a jointer before I don’t see why you couldn’t do the same with these.
I’d also agree with RRBOU on the glue ups.
-- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at http://www.facebook.com/randy.blackstock.custom.wood.designs
View Tootles's profile
Tootles
808 posts in 2495 days
#10 posted 11-01-2014 12:14 AM
Go to the top of the page and in the search box, type “obelisk”. There are quite a few blogs listed that may give you ideas.
I would also be more inclined to use a band saw. I would be thinking along the lines of making a V block to hold the wood being cut, and using the off cuts from one side to get the orientation right for subsequent cuts.
-- I may have lost my marbles, but I still have my love of woodworking
View gfadvm's profile
gfadvm
14940 posts in 2683 days
#11 posted 11-01-2014 12:37 AM
The jointer would be asking for injury with those small pieces. Bandsaw with a jig looks the safest.
View Ub1chris's profile
Ub1chris
116 posts in 1373 days
#12 posted 11-01-2014 02:34 AM
+1 to what gfadvm said. I’ve tapered table legs on the jointer, but they were a lot longer than 6 inches. That’s asking for trouble. Stick to the band saw.
View NoThanks's profile
NoThanks
798 posts in 1522 days
#13 posted 11-01-2014 03:29 AM
I just made a V-shaped cradle and cut this on my chop saw. (All 4 sides, same jig)
It’s only 3 1/2” tall. Could use a sliding miter saw for larger pcs.
-- Because I'm gone, that's why!
wseand
#14 posted 11-03-2014 03:17 AM
Good looking jig, a bit sketchy but if it works and no harm then excellent. What angle did you cut them at.
Although, I don’t think the OP is keeping track of his post.
NoThanks
#15 posted 11-03-2014 04:00 AM
I just did this for a test. If I was going to make them, I would make a more solid jig that would be clamped in place.
These were cut at about 10 degrees, but it would depend on the length you are going to make them. I must say it was very simple, and seemed safe although a better jig would be completely safe if made correctly.
I’m thinking about making one using a 4×4 x 18 with my 16” radial arm saw, but it will have to be when I get the extra time.
