Which shellac to use?
Forum topic by MrRon posted 10-29-2014 10:58 PM 1160 views 0 times favorited 12 replies Add to Favorites Watch
View MrRon's profile
MrRon
5261 posts in 3479 days
10-29-2014 10:58 PM
Topic tags/keywords: question
A jock recommended using a spray coat of shellac on cast iron surfaces to prevent rust. Which shellac do I use, wax or non wax type?
12 replies so far
View ralbuck's profile
ralbuck
5530 posts in 2502 days
#1 posted 10-29-2014 11:08 PM
Where I live winter humidity is a problem for cast iron machine tables and parts. I use a good paste wax and do it usually once a year or so and have no issues! It also helps the work to slide easier.
-- Wood rescue is good for the environment and me! just rjR
View Bill White's profile
Bill White
5148 posts in 4196 days
#2 posted 10-29-2014 11:19 PM
Gotta go with ralbuck. Paste wax for me, and I live in Mississippi. Do you want to now about humidity? :)
Bill
-- bill@magraphics.us
View mbs's profile
mbs
1657 posts in 3176 days
#3 posted 10-30-2014 12:32 AM
Me too.
-- Sorry the reply is so long. I didn't have time to write a short reply.
View oltexasboy1's profile
oltexasboy1
250 posts in 1940 days
#4 posted 10-30-2014 12:52 AM
I also live on the gulf coast and wax is what I use.(obviously in Tex.)
-- "The pursuit of perfection often yields excellence"
View ElChe's profile
ElChe
630 posts in 1572 days
#5 posted 10-30-2014 01:03 AM
Wax on wax off. :)
View Charlie's profile
Charlie
1100 posts in 2522 days
#6 posted 10-30-2014 10:21 AM
For long term storage (over winter… it gets c-o-l-d up here!) I spray with G96 Gun Treatment, let it sit about 15 or 20 minutes, wipe off whatever didn’t dry and then put a couple coats of Johnson’s Paste Wax over that.
SDR
Stuff Don’t Rust
5233 posts in 2729 days
#7 posted 10-30-2014 11:13 AM
If those cast iron surfaces have wood sliding across them, I doubt shellac is going to last very long at all. But for waxed versus de waxed, waxy shellac is only a problem when it’s going to be top coated with something that has urethane resins in it (urethanes have adhesion problems), and then only a “maybe”. So if you want to do this, I’d say use whatever you have…
View OSU55's profile
OSU55
2025 posts in 2225 days
#8 posted 10-30-2014 11:52 AM
Shellac is excellent for sealing a ferrous surface for rust protection, but I wouldn’t recommend it for sliding surfaces, such as a table saw top, except for long term storage. It would be great for any other surfaces. Waxed or dewaxed will work in this application. For an alternative, you could use Alox. I have a review for it on this site. For machine tops, use furniture wax w/o silicone.
View Earlextech's profile
Earlextech
1162 posts in 2926 days
#9 posted 10-30-2014 01:31 PM
Johnson’s Paste Wax!
View RRBOU's profile
RRBOU
176 posts in 2528 days
#10 posted 10-30-2014 02:29 PM
I bought into the shellac for cast also. Big mistake in my opinion. It took about a gallon of denatured alcohol to remove it. Nothing would slide after application, would leave black streaks on what ever you would slide over it also. I tried it with waxed and dewaxed shellac and waxed the surface after. Now I have gone back to just put wax on and have no problems.
-- If guns cause crime all of mine are defective Randy
117417 posts in 3813 days
#11 posted 10-30-2014 03:38 PM
Shellac is not a good barrier for moisture control on wood and I certainly would not use it on my equipment ,like the rest of the gang I use pase wax.
MrRon
#12 posted 10-30-2014 04:28 PM
Thanks. I’ll stay with paste wax.
