Dusty Deputy Passing Most Debris to the Shop Vac
Forum topic by KE4NYV posted 10-29-2014 07:37 PM 1990 views 0 times favorited 29 replies Add to Favorites Watch
View KE4NYV's profile
KE4NYV
136 posts in 1367 days
10-29-2014 07:37 PM
I have the small Dust Deputy and for a while it was working great. I have it set up with my Kobalt shop vac and a metal trash can with a fitted MDF top. For a while, this worked fine. Recently, I noticed that about half of what I suck up is getting passed to the shop vac. I have no idea what has changed. I noticed that most of the debris seems to just spin around and around, without moving down. I’m pretty sure as it spins and stays towards the top, it’s gradually getting sucked up through the top.
I was considering buying the larger Dust Deputy for my Grizzly dust collector, but now I’m not sure I want to spend the money.
Has anyone else seen this?
-- Jason R.
29 replies so far
View ChrisK's profile
ChrisK
1912 posts in 2986 days
#1 posted 10-29-2014 07:45 PM
Sounds like the velocity of the air in the cone has increased. Is there any leaks allowing more air to get in?
-- Chris K
View waho6o9's profile
waho6o9
8099 posts in 2482 days
#2 posted 10-29-2014 07:45 PM
I had a similar situation and couldn’t figure it out but I was thinking
there’s a gap some where around the top of the DD lid so I made
a plywood top to keep it from flexing. The bolts were long enough
and 1/2 plywood was used. Worked better after that.
KE4NYV
#3 posted 10-29-2014 08:00 PM
My original setup with the DD was with a Lowe’s bucket and the snap-on lid. It seemed to work ok, but I filled it up fast. In that case, I didn’t even bother to seal the DD with the lid. I just used bolts all the way around with washers. When I went to the metal trash can, I couldn’t use the stock lid because it’s domed and has a handle in the middle. Instead I cut a disk from MDF and rabbeted the edge all the way around to fit in the top of the can tight. It’s tight enough that I have to pry it off. Also, when I put the DD on, I cut a felt pad to go between the mounting flange and the MDF top to ensure it was air tight. Not sure where my leak could be.
-- Jason R.
4874 posts in 2398 days
#4 posted 10-29-2014 08:35 PM
Are the seams on the trash can sealed?
KE4NYV
#5 posted 10-30-2014 02:06 AM
The best can tell. It was brand new and the seams are all fold over/hook style and then pressed together.
-- Jason R.
View Paul's profile
Paul
721 posts in 1470 days
#6 posted 10-30-2014 02:29 AM
How do you see the dust spin around a metal trash can and a mdf lid?
I’ve had a super dust deputy on my HF DC for over a year and haven’t had to empty the HF DC’s bag once.
Paul
17547 posts in 1761 days
#7 posted 10-30-2014 02:31 AM
Yeah I’m thinking air is coming in thru the trash can somewhere causing air to go up.
#8 posted 10-30-2014 11:16 AM
Those seams need to be taped (foil tape, not duct tape)....they are seldom air tight from the factory. That includes the one around the bottom. You can test this without taping it. Put a plastic trash bag liner in it, being sure to put some weight in the bottom to keep it from being sucked into the ducting. Try it out and see what happens. That trash bag need to extend over the lip of the can, and be sealed by the top.
KE4NYV
#9 posted 10-30-2014 02:56 PM
I ve had a super dust deputy on my HF DC for over a year and haven t had to empty the HF DC s bag once.
I see it spinning around in the top of the DD, not the trash can.
-- Jason R.
KE4NYV
#10 posted 10-30-2014 06:43 PM
Yeah I m thinking air is coming in thru the trash can somewhere causing air to go up.
What has me confused is why it worked when I first put it together. Now, in a matter of a couple of days it’s doing this.
-- Jason R.
KE4NYV
#11 posted 10-30-2014 06:45 PM
OK, I’ll go back and tape the seams. Maybe they are opening up slightly, where I can’t see and causing air to leak in. I can tell you that when I have it on, I can put my hand over the hose and the trash can flexes, trying to collapse on it’self. I know that is a drastic difference from open nozzle to complete blockage, but you would think that it wouldn’t be that noticeable with a small leak.
-- Jason R.
#12 posted 10-31-2014 12:18 PM
It only takes the tiniest of leaks to allow debris past the separator. It’s possible the can was relatively tight at first, and opened up a little with the stress the DC imposed.
KE4NYV
#13 posted 10-31-2014 05:11 PM
It only takes the tiniest of leaks to allow debris past the separator. It s possible the can was relatively tight at first, and opened up a little with the stress the DC imposed.
Good point! I’m running to Lowe’s after work to pick up some foil tape. I think I can get foil tape in the HVAC section for duct work…but not duct tape :o)
-- Jason R.
View buildingmonkey's profile
buildingmonkey
242 posts in 1452 days
#14 posted 11-01-2014 12:35 PM
I understand leaks. My cyclone was filling the filter with dust, and I found a gap between the blower and the cyclone. It had a gasket, but the top of the cyclone was light weight metal, and it just bowed apart and blew out. I took it apart, cleaned it up and put a big bead of silicone between the joint, and let it dry before using it again. Amazing difference. Now my drum is packed full, and hardly anything goes into the filter.
-- Jim from Kansas
#15 posted 11-01-2014 01:01 PM
I’ve had similar problems where it worked great one day and then the next day my shop vac was full of debris.
showing 1 through 15 of 29 replies
