Can you give me your opinion please?
Forum topic by maplerock posted 10-28-2014 08:00 PM 1328 views 0 times favorited 15 replies Add to Favorites Watch
View maplerock's profile
maplerock
529 posts in 1767 days
10-28-2014 08:00 PM
Topic tags/keywords: insulation cold glue wood
I have a very large project about 60% finished. It is two very large pieces, and made mostly of plywood with poplar supports and oak trim. Very large and heavy.
I have been working on it in my detached garage and now am leaving town for 10-11 days with the project incomplete. The weather will run the gamut while I’m gone… from 25-30 degrees to 70-75 degrees. The wood is all indide the unheated building. I do have a furnace in there, but it has so many areas that are not well insulated that it would cost a fortune to heat while i’m gone.
So, here’s the question: I did lots of gluing on this project. Can I leave it in the unheated garage for 2 weeks? What do you guys think? It is an expensive and very important job.
Thanks,
Jerry
-- Jerry... making sawdust in the Knobs of Southern Indiana
15 replies so far
View Ocelot's profile
Ocelot
1960 posts in 2605 days
#1 posted 10-28-2014 08:15 PM
Is this another giant box? ;-)
-Paul
View Gafarmer's profile
Gafarmer
6 posts in 1283 days
#2 posted 10-28-2014 08:16 PM
How much time has the glue had to cure?
View dlgWoodWork's profile
dlgWoodWork
160 posts in 3721 days
#3 posted 10-28-2014 08:36 PM
The humidity changes will have move direct affect than the temp changes will. I would think that in 10-11 days you should be ok. But “should be” is a relative term. If the project is important and expensive, I would move the pieces inside your house. You could still have slight humidity changes, but at least it would be more stable than in the unheated shop.
Better to move the large heavy pieces and not need to, than to not move them and wish you had later.
-- Check out my projects and videos http://dlgwoodwork.com
View richardwootton's profile
richardwootton
1699 posts in 1922 days
#4 posted 10-28-2014 08:57 PM
I know it’s going to suck, but I have to agree with dlg…
-- Richard, Hot Springs, Ar -- Galoot In Training
View doubleDD's profile
doubleDD
7321 posts in 2010 days
#5 posted 10-28-2014 09:18 PM
I agree about the glue being dry. It would also depend on the grade plywood you used. Cheaper plwwood will have a tendency to warp easier. I store baltic birch in the garage and have no problems with the fluctuating temperatures here in Illinois. As others have said you may be taking a chance since we don’t know the project. The temp in the garage won’t fluctuate as much as the out side temps.
View Greg In Maryland's profile
Greg In Maryland
553 posts in 2965 days
#6 posted 10-28-2014 09:45 PM
Jerry,
My personal opinion is to just go on your trip (vacation, hopefully) and relax. If the case work can’t handle what is thrown at it over the next two weeks, then you know. All you have done is discover a problem earlier, because if the case is prone to problems there isn’t anything really you can do to stop it.
Of course my opinion really does not amount to too much to anyone but to me (Do I get a bonus for using four to’s in a sentence?). What I would be concerned with is:
a) smaller partially completed components—By partially completed components I mean drawers, drawer faces, doors, styles, rails, etc. Take all of those inside. Those love to warp when you are not looking.
b) raw materials—I would be concerned with materials you have or are about to cut or dimension. Flat plywood is likely not to be too flat when you return. If this does not apply, don’t go out and buy any materials until after you are back.
c) glue and finishes—glue (and water based finishes, maybe?) freeze. Don’t let this happen.
Good luck!
Greg
View REO's profile
REO
928 posts in 2041 days
#7 posted 10-28-2014 09:49 PM
|It’ll be fine. The glue is dry witch is the top consideration. cabinetry and wood work get moved cross country and spends time in storage units without damage.
View DocSavage45's profile
DocSavage45
8520 posts in 2809 days
#8 posted 10-29-2014 01:14 AM
Moisture is more of an issue than temperature. How big a project? Is it finished on both sides (in and out)? Heat in winter without moisture can do damage.
What is the temp in the shop when you go in? before you turn on the furnace?
And it is better to know know that when it’s finished.
-- Cau Haus Designs, Thomas J. Tieffenbacher
maplerock
#9 posted 10-29-2014 01:25 AM
Thanks guys! It is about 3 large pieces of 3/4 inch oak plywood that I have to assemble later with kreg pocket joints and glue. The biggest parts are 1 1/2” thick, glued and screwed.
If the temp was mild (40-60) the furnace would help and not run too much… if it was 25-40 most of the time the furnace would run a lot. There are lots of gaps (pole barn.)
DocSavage45
#10 posted 10-29-2014 01:32 AM
Maybe you can stuff the leaks with plastic bags until you can get it tightened up? When it’s 30 below here the leaks suck the heat big time . LOL!
Check weather channel online for temps while you are away?
Best of luck.
View Roger's profile
Roger
20923 posts in 2771 days
#11 posted 10-29-2014 10:19 PM
Would they be safe if you wrapped them with moving blankets?? ........Like the cloth ones at Harbor Freight. ??
View Don W's profile
Don W
18686 posts in 2534 days
#12 posted 10-30-2014 12:32 AM
I agree with Greg, if it can’t take 2 weeks unheated, there is more wrong than the weather. It should be fine.
View bondogaposis's profile
bondogaposis
4683 posts in 2318 days
#13 posted 10-30-2014 12:56 AM
If you used Titebond II The glue should be fully cured after 24 hours, after that it shouldn’t matter what the temperature is.
-- Bondo Gaposis
View wseand's profile
wseand
2796 posts in 3008 days
#14 posted 10-30-2014 02:22 AM
I have left projects in the garage for weeks in mid doneness and mid fall/winter and never had any problems. You should be fine.
View MrRon's profile
MrRon
4718 posts in 3210 days
#15 posted 11-04-2014 07:47 PM
If it were me, I would drape a large moving blanket over it and place a small lamp inside. A 15 or 25 W bulb would be ok. Just make sure it’s not touching anything. Put the lamp inside a metal can or under a metal coffee can for safety.
