Need help with euro hinges
Forum topic by americanwoodworker posted 10-28-2014 03:21 PM 955 views 0 times favorited 7 replies Add to Favorites Watch
View americanwoodworker's profile
americanwoodworker
185 posts in 2337 days
10-28-2014 03:21 PM
Guys, need some help with choosing euro hinges. I have never worked with them before so I am a little confused here.
What I have is a framed faced cabinet. The frame is 1.5 inches wide. The door is going to sit flush over the frame.
Where I am mostly confused is where everyone says I need a full overlay hinge for face framed cabinet. But then I get even more options with no explanation. The overlays are different. They range from 1/2” to 1 7/16”. Am I supposed to pick a an overlay hinge that matches the width of the face frame? Or does this mean the amount of the frame that is covered after the door is built would be the overlay dimensions? For example: If the door extends over the frame a half inch on all sides that would be a half inch overlay?
Can someone dumb it down for a dummy?
-- Your freedom to be you, includes my freedom to be free from you.
7 replies so far
View NoThanks's profile
NoThanks
798 posts in 1493 days
#1 posted 10-28-2014 03:37 PM
- americanwoodworker
Correct, most brands have two styles of hinges (straight arm,cranked arm) depending on how much you want your door to hang over the FF would depict which style hinge to use, then you dial in the overlay with the different size mounting plates.
If you could tell us how much of an overlay you want and what brand hinges your looking at someone will be able to tell you what to use.
-- Because I'm gone, that's why!
View Ger21's profile
Ger21
1074 posts in 3095 days
#2 posted 10-28-2014 03:45 PM
Sounds like he’s talking about a face frame hinge, which does not come in straight and cranked. As the OP mentioned, you select them based on the overlay, which is how much the door overlaps the face frame.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
NoThanks
#3 posted 10-28-2014 04:05 PM
Sounds like he s talking about a face frame hinge, which does not come in straight and cranked. As the OP mentioned, you select them based on the overlay, which is how much the door overlaps the face frame.
- Ger21
I use Blum hinges almost every day and they come either way. You just use a face frame mounting plate.
View pintodeluxe's profile
pintodeluxe
5620 posts in 2777 days
#4 posted 10-28-2014 04:15 PM
You will like them, they are pretty easy to work with. The 3 way adjustability is a real plus. Just make sure you don’t get hinges for inset doors. Most Euro hinges sold are for overlay applications.
Good luck.
americanwoodworker
#5 posted 10-28-2014 04:27 PM
Great! thanks everyone
View jacquesr's profile
jacquesr
342 posts in 1387 days
#6 posted 10-28-2014 04:54 PM
Could you share the link for those hinges?
View ChrisK's profile
ChrisK
1942 posts in 3045 days
#7 posted 10-28-2014 07:52 PM
Check out the resources at Blum
http://www.blum.com/us/en/02/90/
Lots of good info
-- Chris K
