That time of year, again
« back to Scrollsawing forum
Forum topic by bandit571 posted 10-27-2014 07:28 PM 1358 views 0 times favorited 10 replies Add to Favorites Watch
bandit571
20225 posts in 2708 days
10-27-2014 07:28 PM
Topic tags/keywords: question pine scroll saw
Time to gear up for a few of these
Only, this year it will be a bit different. Bandsaw USED to do these, but it no longer runs. I do have a $10 13” Craftsman scrollsaw, though. New to this game, so, I picked out maybe too rough a cutter of a blade. Going through 3/4” Pine.
Just six pieces of scrap Pine. Usually, I will stain the body a light brown, with the “antlers” a dark walnut. Glue on a fuzzy red nose, and tie on a big red ribbon around the neck. Rudolph! Eyes were done with just a Sharpie. Might need a few more cups?
Maybe I will try a smaller blade? How small does one go with 3/4” thick Pine?
10 replies so far
View lightcs1776's profile
lightcs1776
4210 posts in 1678 days
#1 posted 10-27-2014 11:08 PM
Nice Christmas project, Bandit.
-- Chris ** If there must be trouble, let it be in my day, that my child may have peace. — Tom Paine **
View sawdust703's profile
sawdust703
270 posts in 1444 days
#2 posted 10-28-2014 03:16 AM
well, I’m no expert, but do quite a bit scroll work myself. Using barn wood, hardwood, etc. right down to 1/8’’ material. Myself I prefer to use a #7 skip blade on 3/4’’ material, & sometimes I will use a #5. It just depends on the project. I make dream catchers from barn wood, with a lot of intricate detail in them. Sometimes I have to use an even smaller blade, it all goes by the project. If your saw is variable speed, just a word of caution, don’t try to get your blade speed to fast. You’re more apt to break blades, & get a rougher finish from trying to cut to fast.
-- Sawdust703
View wseand's profile
wseand
2796 posts in 3066 days
#3 posted 10-28-2014 03:24 AM
Those are Awesome, Bandit, great project. I don’t use my scroll saw enough to help out on that end.
View Jim Finn's profile
Jim Finn
2657 posts in 2946 days
#4 posted 10-28-2014 11:15 AM
I agree with Sawdust. I use Flying Dutchman polar#5 blades for cutting 3/4” stock. #7 also works well. The cut with a scroll saw should not require any sanding on the cut surface. Keep the feed rate down. A scroll saw is much much slower than a band saw, but a much better cut.
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
View kepy's profile
kepy
293 posts in 2298 days
#5 posted 10-28-2014 01:49 PM
I am a fan of the Flying Dutchman reverse tooth blades and for that project, a 5 or 7 should work great.
-- Kepy
bandit571
#6 posted 10-28-2014 03:18 PM
The scrollsaw use pins on the blades. Happen to have a large sack of blades to sort through. We’ll see what is all in the bag.
There is a spot right behind the blade that catches any and all items going over it. Might have to file it smooth before much longer. Looks like a blade had been chewing on the table…..
View poopiekat's profile
poopiekat
4356 posts in 3759 days
#7 posted 10-28-2014 03:29 PM
Well done, Bandito!!
bandit571
#8 posted 10-31-2014 10:00 PM
And, a look at how these turn out
Might be able to cobble five or six out of a new 1×6 x8’ board. This one is from leftovers from a door build.
Hotmelt to glue on a fuzzy red nose. Red ribbon tied in place. Dark walnut stained antlers.
I don’t know, think I should post this thing as a project?
Just a stack of scrap wood…..
View JoeinGa's profile
JoeinGa
7736 posts in 2031 days
#9 posted 10-31-2014 11:07 PM
One man’s scrapwood is another man’s PROJECT!
View jimscrollsaws's profile
jimscrollsaws
1 post in 1328 days
#10 posted 11-03-2014 09:35 PM
Well that turned out really cute! and with plenty of time to go till Christmas! can we expect all of Santa’s reindeer by then? :)
