table saw alignment results - good or bad?
Forum topic by jimmy J posted 10-27-2014 02:54 PM 897 views 0 times favorited 2 replies Add to Favorites Watch
View jimmy J's profile
jimmy J
229 posts in 2555 days
10-27-2014 02:54 PM
question on aligning the arbor on a table saw. with a dial caliper i’ve measured the variance 2 ways
1 – measuring the distance from the mitre track to near saw blade tooth at the front of the table saw. then rotating the blade and moving the caliper to the back of the table saw, and measuring again to the same spot near the same saw tooth. when i do this for several different teeth, i get a variance of 1 to 2 thousandths. is this amount decent?
2 – i measure the distance from the mitre track to near a saw tooth at the front of the saw. then WITHOUT rotating the blade, move the caliper to the back of the table saw measure again (this time to a different tooth since i didn’t rotate the blade). the variance i get here is dependant upon where i start on the blade. but sometime the variance is up to 5 thousandths.
i would think the difference between method 1 and 2 above is that 2 also include any variance due to the blade not being perfectly flat (i’ve used 2 fairly new Freund blades, albeit not their most expensive ones).
what do you guys think? do i need to do anything about this?
2 replies so far
View GregD's profile
GregD
788 posts in 3312 days
#1 posted 10-27-2014 03:00 PM
I use method 1 and would be satisfied with a difference of only 0.002”.
-- Greg D.
View bdresch's profile
bdresch
148 posts in 1784 days
#2 posted 10-28-2014 02:50 AM
Use method 1. 0.002” is good. Also make sure u are doing method 1 with the belt on as it can make a difference.
