9' porch posts yellow poplar
« back to Woodturning forum
Forum topic by REO posted 10-26-2014 08:38 PM 1201 views 0 times favorited 7 replies Add to Favorites Watch
View REO's profile
REO
929 posts in 2311 days
10-26-2014 08:38 PM
I finished these up today. the customer brought me a post that had been repaired before by replacing the rotten segment of the bottom of the post. I glued up the blanks 4.5×4.5 and ten feet long and cut them on a beam saw to assure they were true. I had to couple two lathes together and turn half at a time. I used a router for the cutting tool which helped to reduce bounce from tool pressure. they took about an hour and a half a piece.
the coupler between the lathes and the pattern post.
the lathes set up with the post under way.
the follower is in the lower right of the picture the router is mounted to the crossfeed.
the skate wheels for support. I didn’t need them on the first post but the more I turned on the second the more the second one would deflect so I tossed them on and they did the job. I have never used skate wheels before. I thought that they would erode the soft grain of the wood. In the past I have used a large bore bearing with spacer blocks in the bore and a nail to hold the blocks in place. This was much easier!
7 replies so far
View Wildwood's profile
Wildwood
2526 posts in 2371 days
#1 posted 10-26-2014 09:12 PM
Wow, lot of work but great job!
-- Bill
View Joe Lyddon's profile (online now)
Joe Lyddon
10367 posts in 4289 days
#2 posted 10-26-2014 10:02 PM
That is a HUGE job!
You really worked it out very nicely…
COOL approach…
Thank you.
View TheDane's profile
TheDane
5575 posts in 3900 days
#3 posted 10-26-2014 10:11 PM
I’d say that’s a case of Yankee ingenuity at work! Nice job.
View REO's profile
REO
#4 posted 10-27-2014 01:43 AM
Thanks guys!
View Nubsnstubs's profile
Nubsnstubs
1434 posts in 1967 days
#5 posted 10-27-2014 02:12 AM
Cool, Reo, looks like you got it all figured out. Actually, I think for you it was a piece of cake. I’d still be trying to figure out how I was going to glue it up…........ Jerry (in Tucson)
View waho6o9's profile
waho6o9
8539 posts in 2814 days
#6 posted 10-27-2014 02:32 AM
Amazing work.
View wseand's profile
wseand
2796 posts in 3278 days
#7 posted 10-27-2014 02:43 AM
Incredible work and ingenuity,
