Forum topic by ShaneA | posted 10-25-2014 07:06 PM | 1382 views | 1 time favorited | 9 replies | ![]() |
Topic tags/keywords: deft lacquer hvlp spray finish finishing So…I got myself one of the HF HVLP guns. Spraying Deft gloss lacquer on walnut cabinets. Nothing like trying your first spray project on a full set of cabinets. But, I guess I am unsre of the “last step”. Should the last step be wet sanding, one last light spray coat, waxing? Some other step? I have been spraying outside, trying to view the finish in natural light from all angles to make sure I have it as even as possible. But I really don’t have any experience with spraying other than rattle cans on small projects. Any insight would be appreciated, thanks. |
9 replies so far
#1 posted 10-25-2014 08:35 PM |
I would caution spraying outside, there could be some interaction with the sunlight causing bubbles depending on the heat and conditions. If you haven’t had any problems so far then I wouldn’t worry about it but would keep an eye out for anything happening. -- Because I'm gone, that's why! |
#2 posted 10-25-2014 08:56 PM |
I usually spray a 2-4 mil coat and lightly sand with 400G if needed between coats. I don’t do anything after the last coat on larger projects. However, it depends on the look/feel you are after. The finish can be rubbed out to increase the gloss or dulled if you want to decrease the sheen. Many people will apply a coat of wax to give a very smooth feeling finish especially on small projects like decorative boxes. I work all the way through my intended finishing schedule on scrap to ensure I will get the results I want before attacking my completed project. HTH -- Art |
#3 posted 10-25-2014 10:29 PM |
Since the cabinets take up so much space, outdoors was my only workable option. The sunlight didn’t seem to impact the lacquer. However, when I was putting on the second coat of pure tung oil, the sun didnt do it any favors. I ended up having to re-sand a few of the pieces that were facing the light. It was a PITA. Probably would have been a good idea to get a few projects under my belt with the HVLP set up before diving in, but where would the fun be in that? Thanks for the insight. |
#4 posted 10-26-2014 04:43 AM |
I like to wet sand the final (second) coat of lacquer with water and 1500 grit soft sponges. It leaves a glass smooth surface, without the mess of wax and steel wool. If you thin your lacquer 15-20% it will lay down really nice. -- Willie, Washington "If You Choose Not To Decide, You Still Have Made a Choice" - Rush |
#5 posted 10-26-2014 05:29 AM |
Don’t know about the last step but the first I’d do is get a #4 ford cup and match your finishes vorticity to you nozzle size. Here’s a chart that will help with that. http://homesteadfinishingproducts.com/wp-content/uploads/2014/05/paintspraying_ver3.pdf -- Alaskan's for Global warming! |
#6 posted 10-30-2014 12:13 PM |
I’m confused – you said you were spraying deft lacquer, then later make a reference to 2nd coat of “tung oil”. Slow drying “tung oil” varnishes kind of defeat the purpose of spraying. If you want lacquer, I would recommend a pre-cat lacquer – I’ve had very good luck with Sherwin-Williams. One of the nice things about lacquer (and shellac) is each coat “burns in”, melting some of the previous material, creating a contiguous coat – easy to fix screw ups. For the last coat, sand any rough areas or dust nibs with 400 or 600, and shoot a wet coat. Any rough areas or dust nibs in the final surface lightly sand with 600 or 800 and rub out the scratches. |
#7 posted 10-30-2014 01:31 PM |
Nothing should be necessary after the final coat. I don’t wax cabinetry but I do wax furniture. -- Sam Hamory - The project is never finished until its "Finished"! |
#8 posted 10-30-2014 04:37 PM |
BEER |
#9 posted 10-30-2014 04:51 PM |
It was a pure tung oil, not one of the varnish types. I put two coats on the walnut. Waited a couple of weeks and then sprayed the Deft Lacquer. I think I have them at an acceptable place now. So it will be the extra fun steps now…demo and electrical, plumbing. Just the fun stuff. |
Forum | Topics |
Woodworking Skill Share
12029 |
Woodturning
2107 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4904 |
6695 |
28058 |
CNC Woodworking
212 |
Hand Tools
5409 |
Jigs & Fixtures
1419 |
Wood & Lumber
6232 |
1388 |
Focus on the Workspace
2154 |
1187 |
Woodworking Trade & Swap
4756 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8845 |
