I want to build a "SIMPLE" ROUTER TABLE !!!!!!! How??
Forum topic by EdsCustomWoodCrafts posted 10-24-2014 09:53 PM 1958 views 0 times favorited 16 replies Add to Favorites Watch
View EdsCustomWoodCrafts's profile
EdsCustomWoodCrafts
747 posts in 1253 days
10-24-2014 09:53 PM
Hi
I’m hoping that someone can help me.
I want to build a very simple (beginner level), low budget router table and from my searches online I see a lot of great ideas but if im honest there beyond my skill level. it doesn’t have to have drawers or even a dust collection unit (but I fear that my be necessary).. I have some scrap plywood that I can use.
Im also considering a bench top table!!
Thanks
Ed
-- Thanks Ed “A bad day woodworking is better than a good day working. ~Author unknown”
16 replies so far
View Grandpa's profile
Grandpa
3259 posts in 2585 days
#1 posted 10-24-2014 10:02 PM
If you are considering a bench top model, I would consider purchasing it. Those are cheap here. I am not sure of your location right now but I see that you are 5 or 6 hours ahead of my time zone. I figure you must be in western Europe so I am not sure about the local market. I guess the next question is do you need a table or want to build a table? I would give you a table if you were here. I would build a larger table if it would fit in my shop. Personally I have a large shop so I can think like that. Go large. Around here small tables are everywhere. I was given one last month and have a second one I don’t use. Don’t know about your location. Well I looked and you are an Irishman living in MA. I misread the timeline on the post sorry. Those tables are still everywhere around here.
View Tennessee's profile
Tennessee
2755 posts in 2424 days
#2 posted 10-24-2014 10:07 PM
My first router “table”, simply involved me taking a replacement foot plate for my router at the time, cutting the proper holes into my plywood bench, mounting the plate and putting the router to it from underneath. I adjusted it from underneath. It was crude, but it worked. I fashioned a simple fence from a 2X4 and a piece of angle iron on the back that I drilled to hold the bolts that allowed it to adjust a little on the table. If I remember right, I used a foot switch that I had to keep pressed to keep the router running. A dead man’s switch, so to speak.
View greg48's profile
greg48
594 posts in 2667 days
#3 posted 10-24-2014 10:12 PM
Look for Woodsmith woodworking plan booklet 12 ($3.95 then). I built the freestanding version, but it also comes as a bench top model. I’ve been using mine for 10+ years and rebuilt the top few years back with Baltic birch ply for added stiffnes. If you can’t find the plans on-line, let me know and I will send you my copy.
P.s., a piloted flush trim bit has a ball bearing mounted on the shank either above or below the cutting bit. See Rockler.com
-- Greg, No. Cal. - "Gaudete in Domino Semper"
View gfadvm's profile
gfadvm
14940 posts in 2600 days
#4 posted 10-25-2014 12:19 AM
http://lumberjocks.com/gfadvm/blog/28051
This is one I built very early in my woodworking. I just took some BB ply and some pine scraps and started building. It is still functioning well and NO sag.
View bondogaposis's profile
bondogaposis
4611 posts in 2261 days
#5 posted 10-25-2014 12:47 AM
Here is a simple one.
-- Bondo Gaposis
View MT_Stringer's profile
MT_Stringer
3154 posts in 3140 days
#6 posted 10-25-2014 01:00 AM
Hi
I m hoping that someone can help me.
I want to build a very simple (beginner level), low budget router table and from my searches online I see a lot of great ideas but if im honest there beyond my skill level. it doesn t have to have drawers or even a dust collection unit (but I fear that my be necessary).. I have some scrap plywood that I can use.
Thanks
Ed
- ekapprentice2014
What router do you have?
EdsCustomWoodCrafts
#7 posted 10-25-2014 01:02 PM
Hi
Thanks
Ed
- ekapprentice2014
http://m.homedepot.com/p/Ryobi-1-5-Amp-Fixed-Base-Router-R163K/203325690/
- MT_Stringer
I have a Ryobi fixed base 1.5hp router.. Sorry I should have included that information on my post!!!
View Ger21's profile
Ger21
1074 posts in 3040 days
#8 posted 10-25-2014 01:26 PM
Drill a 1-1/2” hole in a piece of plywood, and bolt your router to it. Lay it on two sawhorses, and you have a router table. Just clamp or screw down another board for a fence.
I work in a cabinet shop, and we often use router tables that are not much more complicated than that.
You might want to add some reinforcing strips on the bottom to prevent sagging.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
View waho6o9's profile
waho6o9
8101 posts in 2486 days
#9 posted 10-25-2014 01:36 PM
Gerry for the win. Done.
MT_Stringer
#10 posted 10-25-2014 02:30 PM
Check out the table Steve Ramsey built on You Tube.
View HarveyM's profile
HarveyM
99 posts in 1932 days
#11 posted 10-25-2014 04:36 PM
Here’s a simple one that’s close to the old Oak Park/Router Workshop TV series style.
http://www.grampasworkshop.net/routertable.html
-- Just a Duffer
View distrbd's profile
distrbd
2252 posts in 2356 days
#12 posted 10-25-2014 07:04 PM
gfadvm,that’s a nice router table,looks very sturdy and easy to use.
I always like the RT designs that you stand in front of the table facing the fence,you can hold short pieces with both hands while routing and pushing it against the fence,very easy and safe.
I just don’t get the table saw extension design that the wing/extension serves as a router table,how would you have full control of the piece if you are standing at one end of the fence.
-- Ken from Ontario, Canada
EdsCustomWoodCrafts
#13 posted 10-25-2014 09:06 PM
Ok… I’ve decided to go for this one
http://www.scottmoore.net/projects/router/...
It’s definately more than I was thinking of doing but I do a fare bit off routering and I’m ready for a decent challenge… Wish me luck .. I’ll probaby finish it in about 6 months….
Thanks for all the suggestions
View Woodknack's profile (online now)
Woodknack
11152 posts in 2290 days
#14 posted 10-26-2014 07:59 PM
Why not take Gerry’s advice and use the simple table while you are building a big table.
-- http://thewoodknack.blogspot.com/
EdsCustomWoodCrafts
#15 posted 10-26-2014 08:49 PM
Why not take Gerry s advice and use the simple table while you are building a big table.
- Rick M.
Rick to be honest I’m not using my router on any projects at the moment and the router table will be my main project until it’s built… I’m not so busy in the shop these days I’m mainly cleaning up and deciding how to cost effectively furnish my basement shop….
Thanks … I might use Gregs table as my router table top anyway as the cabinet is getting a little on the exspensive side
