Best wood filler
Forum topic by Gafarmer posted 10-24-2014 03:46 PM 1634 views 0 times favorited 13 replies Add to Favorites Watch
View Gafarmer's profile
Gafarmer
6 posts in 1221 days
10-24-2014 03:46 PM
Topic tags/keywords: tip trick finishing refurbishing
I am relatively new to woodworking and I want to ask what type of wood filler do you use when you are going to stain a project? Thanks for the help
13 replies so far
View mahdee's profile
mahdee
3844 posts in 1673 days
#1 posted 10-24-2014 04:04 PM
Hi, do you mean sealer or to fill nuts and cracks?
-- earthartandfoods.com
Gafarmer
#2 posted 10-24-2014 04:21 PM
I mean a filler used to fill cracks and nail holes
mahdee
#3 posted 10-24-2014 04:27 PM
I use bondo for cracks that are big. Sawdust mix with glue also works. For nail holes you can use toothpick, matches or sawdust mixed with glue.
View pintodeluxe's profile
pintodeluxe
5566 posts in 2718 days
#4 posted 10-24-2014 04:31 PM
I use the soft colored putty available at paint stores. I think it is actually called “Color Putty.” I mix two colors if needed to obtain the correct color. Here are the two keys if you use this type of putty…
1. Pre-finish the project. Stain, lacquer—- the whole process.
2. Fill the nail holes with color putty, and wipe off any residue around the hole. Use thinner if needed.
3. Use a Q-tip to dab finish on the putty. I use lacquer, but use whatever product you topcoated with in step 1.
This finish on top of the putty is critical to the look of your project. Without a topcoat over your putty, it will lighten as it dries, and will no longer match.
I use this process for installing window and door trim. For furniture applications, I try to build in such a way that nails are not required (Mortise and tenons, biscuits etc).
Good luck.
View MT_Stringer's profile
MT_Stringer
3153 posts in 3136 days
#5 posted 10-24-2014 04:31 PM
I haven’t found any filler that readily accepts stain. I have used the dust from my random orbital sander and some wood glue to fill the nail holes, then sand it.
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 1977 days
#6 posted 10-24-2014 05:13 PM
I have had luck with Famo brand fillers. Sometimes they stain very well, sometimes not, depending on the color, species, and stain. But fills and sands well enough it is worth doing a sample. Especially with the walnut and mahogany. Have had good results with both.
-- Who is John Galt?
View SCOTSMAN's profile
SCOTSMAN
5845 posts in 3490 days
#7 posted 10-24-2014 06:10 PM
I always try to fill with black epoxy for cracks,it looks great with natural cracks.
And with nail holes very fine sawdust I find best, with carpenters glue or epoxy.I can never find the filler stuff you buy to match wood in any way shape or form. If it is a small bit of bad old dirty wood from a previous old point of damage,I always remove the offending piece ENTIRELY and replace with a simlar grained coloured piece.It can be made barely or not noticable.Alistair
View Bill White's profile (online now)
Bill White
4855 posts in 3865 days
#8 posted 10-24-2014 06:30 PM
I have had good results from Timber Mate. Lots of colors available, and the stuff doesn’t go to crap if it dries in the container. Just add a bit of water to reconstitute.
Bill
-- bill@magraphics.us
View bondogaposis's profile
bondogaposis
4601 posts in 2256 days
#9 posted 10-24-2014 06:33 PM
I use a mixture of sawdust from my ROS and hide glue.
-- Bondo Gaposis
View Ross's profile
Ross
142 posts in 1878 days
#10 posted 10-25-2014 10:21 AM
Timber Mate (can be found at WoodCraft) or like MT, sawdust and wood glue.
-- "Man Plans and God Laughs"
runswithscissors
2654 posts in 1930 days
#11 posted 10-27-2014 12:27 AM
I use 5 minute epoxy mixed with sanding dust from the wood species I am working with. Takes stain very well, though it will be darker than the rest of the wood.
View timbertailor's profile
timbertailor
1594 posts in 1329 days
#12 posted 10-28-2014 03:26 PM
I watched a YouTube video not too long ago and it was about wood floor finishing. They sanded the floor and then used a wood filler to go over the entire floor. Does anyone in the flooring business know what they may have used?
Sorry if this is off track, but I thought might be helpful\relevant.
Floor Refinishing Video
View Case101's profile
Case101
107 posts in 1698 days
#13 posted 10-28-2014 07:45 PM
Years ago for filling nail holes in house trim after it was stained used DAP putty and just mixed some stain with it that was used on the wood. Worked great. Have not tried it on woodworking projects.
-- John, New Jersey
