Sharpening 10 inch table saw blades
Forum topic by rantingrich posted 10-24-2014 09:01 AM 3322 views 0 times favorited 13 replies Add to Favorites Watch
View rantingrich's profile
rantingrich
372 posts in 1340 days
10-24-2014 09:01 AM
Topic tags/keywords: sharpening tablesaw
Does any one have any recommendations on how to sharpen 10 inch Carbide tips table saw blades. Preferable a manufactured unit, but would consider a home made rig.
-- Rich
13 replies so far
View knotscott's profile
knotscott
8008 posts in 3370 days
#1 posted 10-24-2014 09:25 AM
I’d recommend having it professionally done. I would not attempt to sharpen a high quality blade myself, and cheapo blades aren’t really worth having unless you’re cutting firewood. $15-$20 once a year or two (for me) gains you access to some very expensive, very precise machines.
View Planeman40's profile
Planeman40
1175 posts in 2755 days
#2 posted 10-24-2014 02:05 PM
I have to agree with Knotscott.
This is not for the home woodworker. I have been woodworking for 60 years and I still wouldn’t sharpen a really nice table saw blade by hand. If you live far away from a sharpening service, make a mailable reusable container for the blade and send it off to a reputable professional saw sharpener like Forrest Blades in New Jersey (http://www.forrestblades.com/). I recommend having two or more blades for your saw. When one gets dull, send it out for sharpening and use another blade. And one more tip. To clean the pitch and gum from your saw blade use plain old oven cleaner. Works like a charm!
Planeman
View distrbd's profile
distrbd
2252 posts in 2441 days
#3 posted 10-24-2014 02:06 PM
I d recommend having it professionally done. I would not attempt to sharpen a high quality blade myself, and cheapo blades aren t really worth having unless you re cutting firewood. $15-$20 once a year or two (for me) gains you access to some very expensive, very precise machines.
- knotscott
+1
This thread piqued my interest ,found these two videos very interesting to watch,Just to see what’s involved in sharpening a 10” blade you should see the machine that’s used to do the job properly,you maybe able to sharpen the face of the carbide teeth but sharpening the bevels needs another machine/another totally different set up.
https://www.youtube.com/watch?v=vXN8yOzOd3g
https://www.youtube.com/watch?v=5L3XekKIEd8
-- Ken from Ontario, Canada
View verdesardog's profile
verdesardog
160 posts in 2606 days
#4 posted 10-24-2014 02:14 PM
Just send them out….....
-- .. heyoka ..
View timbertailor's profile
timbertailor
1594 posts in 1419 days
#5 posted 10-24-2014 02:20 PM
My local wood supplier turned me on to his blade sharpening service.
Just ask them.
runswithscissors
2750 posts in 2020 days
#6 posted 10-24-2014 09:14 PM
HF has a blade sharpener that’s not too expensive, especially with a coupon. You could give it a try with an inexpensive blade to see how it goes, before tackling an expensive blade.
View hoosier0311's profile
hoosier0311
706 posts in 2020 days
#7 posted 10-24-2014 09:33 PM
I have that harbor freight unit. It does work well, but I only use it to sharpen up cheapos that use for processing pallet lumber. For that it’s fine, I will not try it out on my ridge carbides. It has a diamond wheel for carbide tips and another stone wheel for steel blades. It does a great job on steel, so so on the carbides.
-- atta boy Clarence!
View Tennessee's profile
Tennessee
2872 posts in 2509 days
#8 posted 10-24-2014 10:03 PM
I consider myself to be fairly handy, from woodworking to having rebuilt a few car engines in my time, and painted a few cars to boot, and I would never, even on my best day, think I could accurately sharpen a 10” carbide saw blade.
View Picklehead's profile
Picklehead
1041 posts in 1924 days
#9 posted 10-25-2014 12:54 AM
I didn’t want to have to do this, but I guess I have to refer you to this video on youtube that shows you exactly how to do it yourself, for cheap, too. Unless you count the cost of the new blade your gonna need after you’re done!
-- You've got to be smarter than the tree.
hoosier0311
#10 posted 10-25-2014 02:15 AM
Man, that video was,,,,,,enlightening. At least the HF set up has an indexing pawl that lets one take a semi consistent grind on each tooth.
timbertailor
#11 posted 10-25-2014 02:28 AM
Most of the DIY models I have seen only allow you to grind one face\surface.
Send it out.
View MrRon's profile
MrRon
4764 posts in 3238 days
#12 posted 10-25-2014 05:44 PM
Unless you have a diamond wheeled carbide sharpening machine (cost $2000 +), don’t even consider it. Send it out. I have such a machine and do my own blades. I know it would be next to impossible to do a good job without one.
runswithscissors
#13 posted 10-25-2014 09:43 PM
Long ago, I used to sharpen steel blades with a file. I made a blade holder that sandwiched the blade between 2 pieces of plywood, with a bolt through the arbor hole. Loosen the wing nut and rotate the blade for the next tooth. I had a Craftsman Chromedge “planer” blade (hollow ground) that I kept going for years before retiring it. Usually took me about 20 minutes to sharpen the whole blade.
