Worm or Bug Holes
Forum topic by Jonathan posted 10-23-2014 09:15 PM 1179 views 0 times favorited 9 replies Add to Favorites Watch
View Jonathan's profile
Jonathan
25 posts in 1183 days
10-23-2014 09:15 PM
What does one usually do when finding worm holes in wood?
A. Do I ignore the holes and just sand and finish (Danish Oil) as normal?
B. Or do I need to do something first in case they are still alive and eating into the wood, which will affect the final product?
The wood is a slab of Guanacaste
9 replies so far
View richardwootton's profile
richardwootton
1699 posts in 1824 days
#1 posted 10-23-2014 10:13 PM
Is the wood air dried or kiln dried? I have a slab that looks very similar to that, which was used in some outdoor furniture and it has quite a few bug hole like you pictured, but they all appear to be old and vacant. However the holes only appear in the lighter colored sapwood, not in the darker heartwood.
-- Richard, Hot Springs, Ar -- Galoot In Training
View mahdee's profile
mahdee
3830 posts in 1637 days
#2 posted 10-23-2014 11:49 PM
Those are not worm holes. It could be problematic depending on whether the bus are still there or not. Since we are getting into Fall/Winter months, the bugs become less active. So, you can create a suitable environment for bugs; lets say 85 degrees to see if they are alive or dead. bring the project inside, put it on a bunch of newspaper and look for sawdust every week or so. If you don’t see any in a month, you are probably good to go with your finishing process. I usually pour some CA glue in those holes and mix glue and sawdust and force them into the holes. You can use darker sawdust to create a contrast or neutral colors to make it match..
-- earthartandfoods.com
Jonathan
#3 posted 10-24-2014 02:54 AM
@Richard: I don’t know how the wood was dried, but you are correct, the bugs have only bored into the sapwood and not the brown wood.
@mrjinx007: Thank you. I took a needle and poked every hole to try and clear them out. It worked for some, but not for all. They really made some deep holes. I don’t think however that any are alive in there. (Hopefully).
View Yonak's profile
Yonak
986 posts in 1390 days
#4 posted 10-24-2014 03:28 AM
I took a needle and poked every hole to try and clear them out. It worked for some, but not for all. They really made some deep holes. I don t think however that any are alive in there. (Hopefully).
- Jonathan
Jonathan, I wouldn’t be so sure. I recommend taking mrjinx’s advice and be sure. Otherwise you can go ahead and treat the boards with insecticide or a heating treatment without testing first.
Regarding what to do once you’re sure there are no bugs, it depends on what kind of look you want. If you want a rustic look you could just leave them open. Many people like that look and even buy ambrosia wood, with the holes, on purpose. If you want a bit more of a refined look, you could fill them with putty or glue of an appropriate color.
Jonathan
#5 posted 10-24-2014 03:32 AM
Is there a recommended insecticide to use? One that will dry quickly, not ruin / discolor the wood etc.?
Thank you for the putty suggestion.
View Joseph Jossem's profile
Joseph Jossem
492 posts in 2137 days
#6 posted 10-24-2014 03:32 AM
laquer thinner poison and then more thinner probably powder post bugs if that doesnt work gas and a match. they can lay eggs and come out later after you build
Jonathan
#7 posted 10-24-2014 04:38 AM
Is mineral spirits enough or does it need to be lacquer thinner?
Yonak
#8 posted 10-24-2014 04:49 AM
The best method I’ve heard of is putting it inside of a plastic bag with a bug bomb. I can’t attest to this method but I’ve heard of it being done successfully.
Jonathan
#9 posted 10-27-2014 10:54 PM
Thank you all.
I placed the wood on two saw horses covered everything with painters plastic and bug bombed.
