Hi everyone I just inherited my grandfathers old craftsman 113 band saw. Right away I put a new 1/4 inch blade on it. I started cutting a piece of plywood and even though I didn't smell burning or see smoke I have burning on the wood.
I noticed that there isn't any urethane strips on bandsaw tires. Would this cause the burning?
Without the tires your blade is travelling on metal which dulls the blade and cause burning. If the wood is green, it can cause burning. If the tension of the blade is wrong, it can cause burning. Probably combination of all is causing it.
I would suggest that a complete tune up is in order. Tires, check guides, a quality blade, tension, etc.
If ya skimp on any points you will not have a quality cut.
Bill
It is worth some expense but you will never re-saw on this tool. It will cut curves and will be useful. It has many uses in a shop. Some people have a large band saw with a wide blade that is set up for re-sawing and keep a saw like this one with a narrow blade set up for curves.
Keep the one you have and keep your eye out for a bigger saw. I had a homemade bandsaw that got me by for a year or two until I got to buy the bandsaw of my dreams.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
