Strengthening a cracked rasp handle
« back to Hand Tools forum
Forum topic by Brett posted 10-23-2014 03:32 AM 945 views 0 times favorited 2 replies Add to Favorites Watch
View Brett's profile
Brett
660 posts in 2682 days
10-23-2014 03:32 AM
I bought a rasp recently that has a wooden handle which is sound but which has a couple splits along half its length. I’d like to strengthen the handle to prevent it loosening. I know that epoxy will fill the gaps but will it also keep the cracks from spreading? Is there another adhesive that will work better? Thanks.
-- More tools, fewer machines.
2 replies so far
View Woodknack's profile
Woodknack
11626 posts in 2379 days
#1 posted 10-23-2014 05:18 AM
If the handle can be clamped to close up the cracks, just use wood glue. If you can’t close the cracks then use epoxy, I’d dye it black with food coloring or mix it with sawdust. Probably the handle is drying out causing the cracks, stop the drying with a sealing finish like varnish.
10396 posts in 3647 days
#2 posted 10-23-2014 05:33 AM
Wire.
