What to do with a sink cutout?
Forum topic by MT_Stringer posted 10-22-2014 11:37 PM 2335 views 0 times favorited 27 replies Add to Favorites Watch
View MT_Stringer's profile
MT_Stringer
3153 posts in 3136 days
10-22-2014 11:37 PM
Topic tags/keywords: question
The counter top for our kitchen will be installed in a few weeks. I asked the template guy if he was going to cut the sink opening on site or at their shop. He said on site. I said I wanted the cutout. After all, I paid for it, right?
OK, so what am I going to do with a piece of 3/4 inch thick quartz (Silestone)? The sink is 33 inches wide x about 20 inches deep. I might give the installer a tip to clean it up for me.
I have a router table so I don’t need to make another one. All I can think of at the moment is a patio cart. I have a nice gas grill that the cart could sit next to. In my younger days, I would make a fish cleaning station :-) .
Have y’all got any ideas? Throw them out there. I would appreciate it.
27 replies so far
View CharlesA's profile
CharlesA
3305 posts in 1703 days
#1 posted 10-22-2014 11:50 PM
Can you mill it with woodworking tools like Corian? If so, plane it down and make ZCIs. Use it with abrasive for flattening hand planes.
View dhazelton's profile
dhazelton
2687 posts in 2202 days
#2 posted 10-23-2014 12:32 AM
Dead flat surface for scary sharp method of sharpening. Or what you already thought – another small table surface.
MT_Stringer
#3 posted 10-23-2014 12:33 AM
- CharlesA
I don’t know. I will have to check. Thanks
View DKV's profile
DKV
3940 posts in 2409 days
#4 posted 10-23-2014 12:38 AM
Sharpening and small glue ups. Easy glue cleanup.
-- This is a Troll Free zone.
View Ger21's profile
Ger21
1074 posts in 3036 days
#5 posted 10-23-2014 01:11 AM
No, it’s not like corian. It requires the normal tools used for working with stone tops.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
CharlesA
#6 posted 10-23-2014 01:11 AM
No, it s not like corian. It requires the normal tools used for working with stone tops.
- Ger21
bummer.
View timbertailor's profile
timbertailor
1594 posts in 1329 days
#7 posted 10-23-2014 01:12 AM
They made the extra Italian Quartz (Silestone) in our house into a cutting board.
Also doubles as a hot plate. Will not crack like granite when subjected to extreme heat. And since it is basically glass, will not absorb carbonates, or anything else. Very sterile, once cleaned. Its lack or porosity is the key.
Quartz does not leave seams or need to be sealed\maintained. Good stuff and that is why it is three times more expensive than granite. Great product choice Mike.
MT_Stringer
#8 posted 10-23-2014 01:35 AM
Quartz does not leave seams or need to be sealedmaintained. Good stuff and that is why it is three times more expensive than granite. Great product choice Mike.
- timbertailor
Thanks. That is why it was chosen. We used it for our buffet. I like it.
A cutting board sounds like a good idea. A hot plate also.
View Crank50's profile
Crank50
173 posts in 1481 days
#9 posted 10-23-2014 02:33 AM
Maybe I’m wrong, but my understanding of Stilestone is that it’s quartz particles bonded together with resin. Therefore, it can be damaged by high heat before granite can. That is basically the recommendation of a Consumer’s Report evaluation and confirmed by my countertop installer. He was as baffled as I was why people pay way more for quartz. He also pointed out that it did not need sealing because it is manufactured from essentially quartz powder and plastic. It is sealed by the nature of its construction. He does like to sell it because it’s a higher profit product and not as easy as granite to break accidentally.
MT_Stringer
#10 posted 10-23-2014 02:42 AM
Thanks Crank. We already have the Silestone on our buffet. So we stuck with it. My wife likes the idea of no sealing/lo maintenance.
Our buffet
Ger21
#11 posted 10-23-2014 02:51 AM
Not sure why anyone would want to use a stone cutting board, if they wanted any chance of keeping their knives sharp?
MT_Stringer
#12 posted 10-23-2014 02:53 AM
- Ger21
All ideas welcome. Got any?
View Kelly's profile
Kelly
1918 posts in 2849 days
#13 posted 10-23-2014 03:24 AM
If you have a circular saw, you can cut the cutout so it’s square, has corners knocked off or whatever you want. Just pick up a cheap diamond blade and, when you use it, dribble a little water on the cut for cooling. I’ve cut a lot of granite this way.
If you have an angle grinder, you can buy a Harbor Freight diamond blade for it, run painters tape where you’d like to mark it for cutting, say for a circle, then the grinder to cut your lines. By just running around the piece, you can cut shapes limited only by the radius allowed by the cut of a four or five inch wheel.
I buy only variable speed grinders because they allow me to work granite without burning up expensive pads and bits used for these processes. Polishing, for example, requires slower speeds. You can buy a set of pads and, again, with water to keep them cool, you can polish the edges.
Granite supply places (e.g., Master Wholesale, out of Seattle) sell grinding stones you can use to round over the edges (I bit the bullet and bought the router bit for the grinder). They only run about ten bucks and hog a lot of granite off.
Attached is an old planter stand the ex’s grandpa repaired using chipboard. To say it looked like hell was an understatement, but that’s why they invented dollies, eh? Anyway, it just seemed fun to take a cheap pieces of furniture and high end it, so I cut and polished this top, as described.
MT_Stringer
#14 posted 10-23-2014 03:29 AM
If you have a circular saw, you can cut the cutout so it s square, has corners knocked off or whatever you want. Just pick up a cheap diamond blade and, when you use it, dribble a little water on the cut for cooling. I ve cut a lot of granite this way.
Another thing you can do is, run painters tape where you d like to mark it for cutting, say for a circle, then use a angle grinder. By just running around the piece, you can cut shapes limited only by the radius allowed by the cut of a four or five inch wheel.
I buy only variable speed grinders because they allow me to work granite. Polishing, for example, requires slower speeds. You can buy a set of pads and, again, with water to keep them cool, you can polish the edges.
Attached is an old planter stand the ex s grandpa repaired using chipboard. To say it looked like hell was an understatement, but that s why they invented dollies, eh? Anyway, it just seemed fun to take a cheap pieces of furniture and high end it, so I cut and polished this top, as described.
- Kelly
Good info. Thanks.
View watermark's profile
watermark
483 posts in 1848 days
#15 posted 10-23-2014 09:00 AM
A lot of good ideas already. Here is something I made with granite left overs.
-- "He who has no dog, hunts with a cat" Portuguese proverb
