How would you do this?
« back to Joinery forum
Forum topic by lateralus819 posted 10-22-2014 02:49 AM 1059 views 0 times favorited 8 replies Add to Favorites Watch
View lateralus819's profile
lateralus819
2241 posts in 1858 days
10-22-2014 02:49 AM
Looking for some insight.
Building a small vallet box like this
I need to hide the end grain exposed from the sides. I origianlly was going to make a drawer extend to the sides but i don’t really like that idea. Then i thought maybe about veneer?
Any ideas?
8 replies so far
View Loren's profile
10278 posts in 3616 days
#1 posted 10-22-2014 02:57 AM
If you’re going to ebonize it, I recommend not
worrying about the end grain. Just thoroughly
dye your filler and fill the pores well. With
pores filled the end grain becomes much less
obtrusive.
lateralus819
#2 posted 10-22-2014 03:00 AM
Sorry should had elaborated Lored.
It’s made from mahogany. I was just referring how there is a drawer in the front and exposed endgrain.
View Don W's profile
Don W
18686 posts in 2536 days
#3 posted 10-22-2014 11:14 AM
All end grain seems to be in the front, so what side end grain will there be?
Other than veneering you could miter it.
View Yonak's profile
Yonak
986 posts in 1490 days
#4 posted 10-22-2014 01:25 PM
You could employ breadboard ends but then, of course, you’d have a bit of end grain at the top corners.
View CharlesA's profile
CharlesA
3312 posts in 1766 days
#5 posted 10-22-2014 01:50 PM
I’m a bit confused. Are you concerned about the end rain showing in the front beside the drawers? Why do you need to hide it? How will you finish it?
View brtech's profile
brtech
1028 posts in 2891 days
#6 posted 10-22-2014 02:10 PM
It’s hard to see why it will be bothersome. You certainly can use veneer tape easily enough if you want to. You would be able to see the edge of the veneer from the side, but it is very thin.
You can use miters only if you make the drawer narrower.
You could also consider using a box joint for all 4 corners, which doesn’t cover the end grain, but incorporates it as part of the design.
Use the trick of an extra sanding step with a higher grit on end grain so it absorbs less finish.
View Woodknack's profile
Woodknack
11487 posts in 2349 days
#7 posted 10-22-2014 03:39 PM
Two ways to hide the end grain completely are an overlay drawer front or mitered edge banding.
edit; just realized you don’t want to do an overlay drawer.
View JayT's profile
JayT
5589 posts in 2180 days
#8 posted 10-22-2014 03:47 PM
Full blind dovetails come to mind. Never done them, but they would give plenty of strength and not show end grain.
My other thought would be splined miters.
