Need template for boot jack curved ends of six board chest
Forum topic by DW833 posted 10-22-2014 02:32 AM 1955 views 0 times favorited 7 replies Add to Favorites Watch
View DW833's profile
DW833
220 posts in 2120 days
10-22-2014 02:32 AM
Topic tags/keywords: six board chest template design
I’m building a six board chest using pine. Looked a several designs and tried to draw something up for the
boot jack curved ends. Every design I come up with looks off. Tried using a compass and various instructions
I’ve found online. However, still no success at a decent layout on the ends. Does any one have a template or know where I can get one.
thanks
7 replies so far
View pmayer's profile
pmayer
1032 posts in 3303 days
#1 posted 10-22-2014 03:06 AM
Can you post a picture of your rough sketch and your dimensions so that it is more clear what you are attempting? I’d be happy to give it a shot for you and send you a PDF if I can come up with something in the ballpark.
DW833
#2 posted 10-22-2014 03:20 AM
Here is the link to the plan I started with.
http://www.finewoodworking.com/FWNPDFfree/six-board-chest.pdf
pmayer
#3 posted 10-22-2014 03:44 AM
Since it was included in the plan, I took a copy of the boot jack image from page 4 of the plan and put it at scale in a PDF file. I added a line to indicate the height of the boot jack so that when you print it you can be sure that it is to scale. You will either need to be able to tile print on an 8.5×11 printer, or send it to an 11×17 printer (Kinkos has these if you don’t have other options). You would just print this to scale, use spray adhesive to lightly mount it to the work piece, then cut it out.
If you’d like me to send this to you, send me a PM with your email address.
DW833
#4 posted 10-24-2014 12:29 AM
Paul,
Thanks for your reply. Sorry about the delay in responding. I didn’t think of enlarging the image. Not clear on how to do it anyway. I’m having an issue with my personal email. Could you reply in the forum and attach the image to the message.
Thanks,
david
pmayer
#5 posted 10-24-2014 02:21 AM
DW833
#6 posted 10-24-2014 03:45 AM
Thanks Paul. I’ll print this over the weekend and use it. Thanks.
pmayer
#7 posted 10-24-2014 04:15 PM
No problem. Good luck, David.
