hole spacing on handles
Forum topic by daddywoofdawg posted 10-22-2014 02:24 AM 832 views 0 times favorited 7 replies Add to Favorites Watch
View daddywoofdawg's profile
daddywoofdawg
1028 posts in 1573 days
10-22-2014 02:24 AM
Is there a standard hole spacing on handles, like kitchen cabinets and size of finger groove on pulls?
7 replies so far
View JAAune's profile
JAAune
1798 posts in 2314 days
#1 posted 10-22-2014 04:43 AM
Three inches is very common for hole spacing but it’s not the only length available.
View Gshepherd's profile
Gshepherd
1727 posts in 2199 days
#2 posted 10-22-2014 06:28 AM
To make things easier they make some fairly cheap plastic hole spacing jigs. Depending on which hardware your going to use.
-- What we do in life will Echo through Eternity........
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2367 days
#3 posted 10-22-2014 12:26 PM
When we re-finished out bathroom vanity, the spacing was not the same on the new hardware as was on the old. I made a template from scrap, took about 5 minutes, that registered on the top corner of the door, and had the holes drilled for the hardware. Just put it on the door, drill, do the next door. If you have 2 doors to do, probably not worth it. We had 6, so it made sense for me, to make sure they were all consistently located without measuring each one. Easier to do it right once on scrap, then you can mindlessly drill the doors/drawers.
View junebug's profile
junebug
101 posts in 2402 days
#4 posted 10-22-2014 12:32 PM
the most common at our shop is 4” and 96mm
daddywoofdawg
#5 posted 10-22-2014 01:14 PM
The reason I’m asking is I making some handles,And the handles I have are old fashion type so know measuremerments I can get off them.is there like so many inches in from the end on the bar style handle.
here is what I mean by bar style
http://www.build.com/liberty-hardware-p01012-cabinet-pull/s633865?uid=1165015&source=gg-gba-pla_1165015____58419134119&s_kwcid=PTC!pla!!!72167402130!g!!58419134119!&gclid=Cj0KEQjwq52iBRDEvrC12Jnz6coBEiQA2otXAlE_0rkNtjj7FrK8jq2daMWFQcmoTQGatjaAnV5wsHAaApqq8P8HAQ
Center to Center Length: 3.78” (96mm) what do they mean from one leg to the other?
View verdesardog's profile
verdesardog
160 posts in 2609 days
#6 posted 10-22-2014 02:03 PM
As a cabinet maker I have found that there are two different common spaced pulls, 3’ and 3 1/2”, of course there are metric also which are close to that. But when you go custom they can be anything the manufacturer decides…..
-- .. heyoka ..
View MrRon's profile
MrRon
4769 posts in 3241 days
#7 posted 10-23-2014 08:34 PM
Not sure if I understand your question; are you concerned about the hole spacing or the position of the handle? The normal location of a drawer pull is in the center of the drawer panel, but depending on the style and shape of the handle, it could be somewhat above center, but usually not below center. It’s an aesthetic thing. Once you have found the most pleasing location for the handle, make a template so all handles will locate the same.
