Custom granite top router table for sale
Forum topic by Troy Cleckler posted 10-21-2014 02:58 AM 1777 views 0 times favorited 0 replies Add to Favorites Watch
View Troy Cleckler 's profile
Troy Cleckler
385 posts in 1367 days
10-21-2014 02:58 AM
Asking 375.00. I use it a lot but due to needing more floor space willing to let it go and get ont to fit table saw wing. I made the router plate adjustable and the router is adjustable from the top and has a lock to change bits with one wrench. The router is a combo and I’ve never used the plunge base. Router is a Frued 2-1/4 hp 13 Amp. Also leaving the Incra Ultra fence system with it. I have the master template book as well. This fence is good for box and dovetail joints and for the larger raised panel bits I’ve made a fence system that goes with it as well.
It’s wired to be turned on and off by switch on front of table. Extra bonus, large flat surface to sharpen irons and chisels.
Because of the weight, guessing around 150 pounds or better, I’d rather it be picked up here. I’m in central Alabama. If you are willing to pay for the truck shipping, I might be able to work something out.
-- Troy. - Measure twice, cut once and fill the gaps....
0 replies so far
