Votice Candle Holder 1.5", wont fit!
Forum topic by stokes776 posted 10-20-2014 01:29 PM 738 views 0 times favorited 2 replies Add to Favorites Watch
View stokes776's profile
stokes776
1 post in 1314 days
10-20-2014 01:29 PM
Topic tags/keywords: question drill-driver arts and crafts
So I made a little votive candle holder, just a tealight candle.
I went out and got a Forstner bit and drilled it in. But when I try to put in a candle, it wont fit, the candle is just slightly bigger.
I understand the problem here, the candle is just slightly bigger than 1.5”.
My question is, what is the best way to resolve the problem? Should I try to sand it enough to remove enough material to get it to fit?
Try to use a drill bit and remove material from the sides? (This might result in a less than perfect circle).
I will try to upload a picture when I get home!
2 replies so far
View ChefHDAN's profile
ChefHDAN
1062 posts in 2845 days
#1 posted 10-20-2014 01:35 PM
Shave candle???
View pmayer's profile
pmayer
1028 posts in 3061 days
#2 posted 10-20-2014 01:52 PM
You could make a template using a larger forstner bit, then lay that over the top of your workpiece and use a flush trim bit to enlarge the circle to that diameter. Or, you could make a slightly larger circle and use a router with bushing to cut to that size.
