Where to lubricate a cutter-head bearing?
Forum topic by Rayne posted 10-19-2014 06:34 PM 1052 views 0 times favorited 4 replies Add to Favorites Watch
View Rayne's profile
Rayne
911 posts in 1565 days
10-19-2014 06:34 PM
Topic tags/keywords: question
Hey Everyone, Could someone point out how to lubricate, say, a jointerr’s bearing? I took a portion of the cutter-head apart (restoring a jointer), and it seems like there was grease or something in there between the bearing and the block that houses the cutter-head support. Is friction holding the bearing in place inside the housing, along with the cutter-head spindle inside the bearing or do I really need to grease everything in and around it? I’d appreciate any feedback.
View Ger21's profile
Ger21
1074 posts in 3156 days
#1 posted 10-19-2014 06:36 PM
It depends on the specific jointer. Most newer jointers would have sealed bearings that don’t require grease, and are actually impossible to grease. Older jointers that require grease will usually have a grease fitting.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
Rayne
#2 posted 10-19-2014 06:53 PM
Here are 2 images of this particular cutter head. The bearing doesn’t seem that bad, but there are a lot of caked on stuff inside, thus the possibility of buying a new bearing.
View MrUnix's profile
MrUnix
6766 posts in 2224 days
#3 posted 10-19-2014 07:05 PM
Those are sealed bearings, so no additional grease is needed. The bearing in the first picture doesn’t look to be in the best of shape, so I’d go ahead and put in new ones while you have it apart. No grease should be in the bearing housing.
Rayne
#4 posted 10-19-2014 08:43 PM
Thanks for the help! I’ll get some new bearings and install them as-is.
