Air cleaner filter
Forum topic by Bill7255 posted 10-19-2014 02:37 PM 852 views 0 times favorited 2 replies Add to Favorites Watch
View Bill7255's profile
Bill7255
427 posts in 2252 days
10-19-2014 02:37 PM
I have a jet air cleaner. I need to replace the furnace type filter on it. I believe the Jet replacement is a MERV 7. The jet filter cost about $20, however a regular MERV 7 that size is about $3. What is the difference? Any reason to buy the Jet filter?
-- Bill R
2 replies so far
View hairy's profile
hairy
2658 posts in 3500 days
#1 posted 10-19-2014 03:10 PM
I think your Jet and my Powermatic use the same filters, 12” x 24” x 1”. You asking about the outer filter? I get mine at Lowes. You can spend as much as you want. I get the cheapies, the inner filter does all the heavy lifting. Inner filter can be blown out and used again. Installed at purchase is 5 micron outer, 1 micron inner.
http://www.lowes.com/Search=furnace+filter+12+x+24+x+1?storeId=10151&langId=-1&catalogId=10051&N=0&newSearch=true&Ntt=furnace+filter+12+x+24+x+1#!
-- My reality check bounced...
View Westernspirit's profile
Westernspirit
13 posts in 1283 days
#2 posted 10-19-2014 07:56 PM
My recommendation would be an electrostatic or metal mesh outer filter which can be cleaned rather than replacing it. Also they collect more of the dust than furnace type filters and making it almost unnecessary to replace the more expensive inner pocket style filter.
-- Western Spirit Bev
