What did I do wrong?
Forum topic by thewfool posted 10-18-2014 10:35 PM 1742 views 0 times favorited 32 replies Add to Favorites Watch
View thewfool's profile
thewfool
5 posts in 1442 days
10-18-2014 10:35 PM
Topic tags/keywords: tablesaw safety
I’m a beginner with woodworking, so I’m trying to be as safe as possible. However, there are some things that I just don’t seem to know.
I was working with a piece of hard maple, ripping it into smaller sections on my table saw. I was able to complete three cuts similar to the one pictured below with no issues, but on this last cut, the board jumped up and back at me. It wasn’t very hard and didn’t go very much out of control. I was pushing with a push stick. Can anyone tell me what’s wrong with this setup … and more importantly, how can I do it better next time? The board wasn’t damaged too badly, but I’m not going to finish it until I figure out the problem.
Thanks for any help you can give!
32 replies so far
View Redoak49's profile
Redoak49
3076 posts in 1893 days
#1 posted 10-18-2014 10:48 PM
It is really hard to tell from your picture. Perhaps, you could post one which is not such a close up including your push stick.
A few more details are also needed…..size of the piece of wood and size of the pieces you were cutting off.
View Logan Windram's profile
Logan Windram
344 posts in 2366 days
#2 posted 10-18-2014 10:49 PM
Blade not parallel to the mitre slot, fence slightly out of alignment, poor quality blade, stock not 4 square…
Or things just happen.
Push stick. What kind? I don’t care for the ones that are long with a notch where you are pushing the timber like using a drumstick… I prefer the ones that go over the Tiber and are notched in the back, the basic push stick, while preferable over fingers leaves way to much moving around between that fence and blade, Irving knife aside.
I’d find a good resource on setting up a table saw and safe use. Other than that, be careful.
View hoosier0311's profile
hoosier0311
706 posts in 1930 days
#3 posted 10-18-2014 10:49 PM
Not claiming to be an expert here, but maybe there was a bit of a twist or bow in that particular board that allowed it to bind up?
-- atta boy Clarence!
View retfr8flyr's profile
retfr8flyr
380 posts in 1573 days
#4 posted 10-18-2014 11:03 PM
Can’t tell from the pic but does the blade have a riving knife? Some of the problems could be fence not aligned properly, blade not aligned with the miter slot, the push from the rear, with the push stick, could have made the piece turn slightly away from the fence and into the blade, or you may have done nothing wrong and it was just stress in the wood that made it close up on the blade.
-- Earl
thewfool
#5 posted 10-18-2014 11:09 PM
Here’s a pulled back image to show the board and the push stick.
Here’s a smaller version of the first one, showing the technique I was using.
The board was 2×3x24, and I was ripping it down to 2 1/4. It doesn’t have any obvious twists, knots, or cupping, it’s very straight (somebody else milled it).
View NoThanks's profile
NoThanks
798 posts in 1433 days
#6 posted 10-19-2014 12:09 AM
Dull blade, blade to low-not enough down bite, fence not parallel, didn’t hold the board down strong enough towards the front, other factors could have contributed as well, such as the board relieving stress and bowing.
-- Because I'm gone, that's why!
View Manitario's profile
Manitario
2604 posts in 2787 days
#7 posted 10-19-2014 12:18 AM
This sometimes happens to everyone, beginners and professionals. You experienced kickback, which has happened to almost everyone. Yes, there are obvious causes to look for, like some other LJ’s have mentioned, but sometimes everything can be right and you still get kickback. That is why we use pushsticks, blade guards and riving knives. As well, sometimes when cutting thick stock it will slightly pinch the blade as you cut it and want to kick back. I frequently cut thick stock and occaisionally have this happen, despite using a well aligned TS and a sharp blade.
View mahdee's profile
mahdee
3844 posts in 1672 days
#8 posted 10-19-2014 12:27 AM
I think it was the figures on that wood that caused it. Once it gets hot, then things tend to bend out of shape. You didn’t do anything wrong, just expect that when you run across that kind of discrepancies in wood grain and allow an additional 1/8” to straighten things out later. Make the cut as quick as you can to prevent heat causing problems in your cut.
-- earthartandfoods.com
View exelectrician's profile
exelectrician
2327 posts in 2332 days
#9 posted 10-19-2014 03:58 AM
Were you holding the board DOWN with your left hand while you were pushing with your right hand? Taking care to let the board slide through your down pressure exerted by your left hand, and NOT letting your left hand be carried forward toward the blade?
-- Love thy neighbour as thyself
17540 posts in 1761 days
#10 posted 10-19-2014 04:06 AM
I’m thinking a combination of blade height and not having enough down pressure. Sometimes with the blad set low as for a rip of a thin piece if you just hold the back down with the push stick the front can rise up. Think of the direction the blade is going. It’s coming up and out of the saw so if a little extra pressure pushes sideways into the blade it will lift the wood up.
View splinterking's profile
splinterking
67 posts in 1942 days
#11 posted 10-19-2014 04:24 AM
I agree with what has been said, but I would put my money on the push stick. I’ve noticed in the past that that particular style can cause the board to pivot up and wobble back down. Then the blade will kind of catch it at the apex of its rotation applying the force back at you instead of down towards the table and through the wood. Buy a push stick like the one in pic 1 or make one like in pic 2 or both and it will give it both downward pressure and a forward push.
-- "Clothes make the man. Naked people have little or no influence on society." ~Mark Twain
View mudflap4869's profile
mudflap4869
1562 posts in 1363 days
#12 posted 10-19-2014 04:37 AM
Just a random thought. Cleaning and waxing your fence and riving knife might help a bit. It doesn’t take much to gum them up and cause them to drag on the wood. Attach a feather-board to the fence to hold the work down. The figuring in the board you show will cause it to pinch closed on the blade. when I have a problem with this I sometimes insert a shim in the cut end to maintain the kerf. I use a push stick like the black one pictured above. Great investment in your safety, and lots of useful features.
-- Still trying to master kindling making
View pintodeluxe's profile
pintodeluxe
5566 posts in 2718 days
#13 posted 10-19-2014 04:38 AM
1+ splinterkings advise on that particular shape of push sticks.
I started with a push stick just like yours (started with the same tablesaw too), and found that it pushes the board forward just fine but it also tends to lift the leading edge of the board. That can cause kickback as the blade lifts the board. There are several solutions like expensive saws with riving knives, featherboards, or just a sawhandle type pushstick.
Good luck and glad you didn’t get hurt.
View muleskinner's profile
muleskinner
896 posts in 2341 days
#14 posted 10-19-2014 04:44 AM
I think Splinterking is on the right track. Pushing that much board with that pushstick without a featherboard seems risky – no lateral control. Personally, I’d throw that stick away and make something like Splinter’s second picture. (I’ve never understood the logic of having a couple thousand dollars of woodworking equipment and buying a push stick)
-- Visualize whirled peas
View Fettler's profile
Fettler
200 posts in 1901 days
#15 posted 10-19-2014 07:21 AM
If the work piece is lifting then it’s probably binding on the blade. This could be the result of an out of square work piece or a misaligned fence.
-- --Rob, Seattle, WA
showing 1 through 15 of 32 replies
