First Crosscut Sled Test Build--what is close enough
Forum topic by 69BBNova posted 10-18-2014 08:04 PM 1148 views 0 times favorited 2 replies Add to Favorites Watch
View 69BBNova's profile
69BBNova
341 posts in 2239 days
10-18-2014 08:04 PM
Hi everyone,
My question is how fussy should I be…
I used the 5 cut method, and I’ve adjusted once so far…
I’m a little tired right now but it will hold .015”-.020” taper over 12” length strip…
Can I leave it that way for now or how much better should it really be…
I just need a break for now.
Thanks in advance.
2 replies so far
View dschlic1's profile
dschlic1
432 posts in 1992 days
#1 posted 10-18-2014 09:27 PM
If that is 15 to 20 thou difference at the cut off strip, then you are out about 3 to 4 thousanth over 12”. That comes out to be about 0.0003* per inch. Most precision squares are not that good.
69BBNova
#2 posted 10-18-2014 10:07 PM
Thanks for the info…
I guess I figured it wrong…
Keep in mind I’m exhausted, I don’t know why but I started two different things yesterday from 10:30am Friday and didn’t stop until 6:30am Saturday…
I’ll tell you all I do know is that the strip was measured at about .010”-.013” or so over its 8 inch length, and then I just guessed, so once again I’m missing a huge chunk of the whole picture, I really don’t know.
But Thank You.
