Reusable Shop Vac Bags - Was I the last to know?
Forum topic by gsimon posted 10-18-2014 04:32 PM 3887 views 0 times favorited 6 replies Add to Favorites Watch
View gsimon's profile
gsimon
1272 posts in 2142 days
10-18-2014 04:32 PM
Topic tags/keywords: dust control shop vac shop tips tip
Bothered by spending good money on glorified paper bags I just cut one end off, folded and stapled it. I just undo each time to empty
-- Greg Simon
5002 posts in 2522 days
#1 posted 10-18-2014 05:15 PM
I took a piece of plastic pipe, cut a 1/4” slit in it lengthwise and slide it over the end of the bag when I fold it back over. They still wear out from that after about 2-3 openings (then I glue that end closed, and use the other end), but that’s better than buying new bags every time.
View timbertailor's profile
timbertailor
1594 posts in 1453 days
#2 posted 10-19-2014 02:11 PM
I suggest buying the best filters you can afford.
Not much good vacuuming up saw dust, to just blow the dangerous, small particles back into the air.
I send the exhaust of the shop vac back through my separator. It uses a 0.5 micron cartridge filter.
#3 posted 10-19-2014 02:24 PM
Even with a good filter (I use Gore Clean stream in my vacs) the bags present an advantage. The keep the filter cleaner, longer. They also make emptying the vac a little easier, excluding the work done with the bag to re use it.
View Scottlj's profile
Scottlj
88 posts in 1747 days
#4 posted 05-27-2015 02:03 AM
I wonder if a potato chip bag clip type thing would work to keep the end of a slit and then folded over bag would work. I may try it. Can’t hurt.
gsimon
#5 posted 05-27-2015 03:00 AM
I say give it a try. Heck I’m going to try it and the pipe sleeve as well. I would be a purest if I could afford the best solution to each and every woodworking situation but in this case I wear my mask to empty and clean the bag out doors and I still have a sealed paper bag with some life in it
-- Greg Simon
View Oughtsix's profile
Oughtsix
42 posts in 1204 days
#6 posted 05-27-2015 06:24 AM
I use the biggest yellow drywall bags I can find in my shop vac. Flow is all about surface area and filters (especially fine filters) plug way too quick. A large drywall bag will still flow very well even when it is packed. I just throw them away when I am done… I have a dust collector so my shop vac is for clean up not dust collection so a bag lasts a good amount of time for me.
Cool idea though!
