Is there such thing as a 1/4'' diameter pattern bit for box joints on the dovetail jig?
« back to Joinery forum
Forum topic by Patrick posted 10-18-2014 12:26 AM 909 views 0 times favorited 2 replies Add to Favorites Watch
View Patrick's profile
Patrick
41 posts in 1218 days
10-18-2014 12:26 AM
I figure if your bearing rides against the jig, you should get perfect box joints every time. The only problem is I can’t find a pattern bit with a diameter smaller than a 1/2 inch.
2 replies so far
View pintodeluxe's profile
pintodeluxe
5546 posts in 2689 days
#1 posted 10-18-2014 12:39 AM
You can use a straight bit and a bushing guide on your router. The dovetail jigs instruction manual will tell you what size bit to use.
View Loren's profile
9774 posts in 3524 days
#2 posted 10-18-2014 01:08 AM
