Hand brace bit storage
« back to Hand Tools forum
Forum topic by GeneralDisorder posted 10-17-2014 06:19 AM 6771 views 10 times favorited 8 replies Add to Favorites Watch
View GeneralDisorder's profile
GeneralDisorder
45 posts in 1247 days
10-17-2014 06:19 AM
After a couple failed attempts to create a bit storage rack for the wall hung cabinet I’m making , I came up with this. Holes for the bigger bits were 3/8ths, then stepped down for the smaller shanks. The holes were drilled down the center of a piece of oak about 1-1/8” wide then split on the table saw. The bottoms of the side pieces were cut on an angle and capped with a thin strip. Access is easy and the bits only need to be raised about 1/2”.
C&C always welcome.
8 replies so far
View BinghamtonEd's profile
BinghamtonEd
2286 posts in 2277 days
#1 posted 10-17-2014 03:24 PM
That’s a nice solution. I’ve got my bits and braces all laid out waiting for me to build them a home, I may use some of your construction techniques. I assume that the beveled bottom keeps them from tipping forward, but what keeps them sliding down and tipping back? I was thinking of having a flat bottom, with holes drilled for the ends to sit in.
GeneralDisorder
#2 posted 10-18-2014 02:02 AM
The beveled bottom kicks the bottom out and the top angles back so the bit fits with no further movement.
View Tim Anderson's profile
Tim Anderson
152 posts in 1638 days
#3 posted 10-18-2014 02:42 AM
That’s a really cool idea. I’ve just picked up a set of brace bits, so I will definitely take this design into consideration as I design a holder for my own bits. Looks like it would be easy to get them in and out but keep them from rattling about in loose holes.
-- -Tim, Salt Lake City, UT, USA
View rhybeka's profile
rhybeka
3741 posts in 3029 days
#4 posted 08-14-2016 02:31 PM
Sweet idea, GD!
-- Beka/Becky - aspiring jill of all trades, still learning to not read the directions.
View mike02130's profile
mike02130
167 posts in 580 days
#5 posted 08-14-2016 02:52 PM
I like the tri-levels.
-- Google first, search forums second, ask questions later.
View Andre's profile
Andre
1668 posts in 1713 days
#6 posted 08-14-2016 04:26 PM
Great idea, another one added to the to do list! like the way you hung the brace.
GeneralDisorder
#7 posted 08-14-2016 09:23 PM
Thanks Andre. Have added more to the tool cabinet since this old post and should post an update.
View Handtooler's profile
Handtooler
1497 posts in 2039 days
#8 posted 08-15-2016 02:41 AM
Super work. this idea has a lot of great compact storage for your prized bits. Do you have a/multiple holes for the auger files there as well?
-- Russell Pitner Hixson, TN 37343 bassboy40@outlook.com
