8 tpi rip saw?
« back to Hand Tools forum
Forum topic by 12strings posted 10-16-2014 10:54 AM 946 views 0 times favorited 1 reply Add to Favorites Watch
View 12strings's profile
12strings
434 posts in 2349 days
10-16-2014 10:54 AM
I have procured a good old Diston d23 hand saw for about $5… 8tpi, what I assume used to be crosscut. (difficult to tell now, since there is some wear on the teeth.
Since I already have a decent crosscut saw, I’d like to sharpen this as a rip saw…is 8tpi to fine?
I know Its more teeth than a normal rip saw, but will it simply cut a little slower, but be a nicer cut?
-- I'm strictly hand-tool only...unless the power tool is faster and easier!
1 reply so far
View bold1's profile
bold1
293 posts in 1811 days
#1 posted 10-17-2014 12:43 AM
Can be done. It wouldn’t work well in any but dry wood as the teeth would want to clog. Put in all the set you can to widen the kerf so it will clean better. I’d prob. file it flat and recut it a no more then 6tpi. The finer the teeth the slower the rip. They are also harder to keep a straight rip if they want to clog.
