t-slotted extruded aluminum fence rails?
Forum topic by UltramaticOrange posted 10-15-2014 04:20 PM 1704 views 0 times favorited 7 replies Add to Favorites Watch
View UltramaticOrange's profile
UltramaticOrange
7 posts in 1236 days
10-15-2014 04:20 PM
Topic tags/keywords: table saw fence
Does anyone out there have experience with t-slotted extruded aluminum used with linear bearings (see example links)? I was planing on using them to expand the reach of my fence on a cabinet for my table saw, but if there’s too much play on those bearings, I need a new plan.
extruded t-slots: http://www.mcmaster.com/#t-slotted-framing/=u5w8s9
linear bearings for t-slots: http://www.mcmaster.com/#=u5w94m
-- Happiness is measured in grit.
7 replies so far
View ChrisK's profile
ChrisK
1907 posts in 2985 days
#1 posted 10-15-2014 04:29 PM
First look for an 80/20 distributor, should much cheaper than McMaster. http://8020.net/
The bearing will probably need to be shimmed to make the bearing not wobble too much. However to tight and the bearing will not move easily. The extrusions I have used in the past are pretty straight, so no problem there. Bu the linear bearings are sloppy.
-- Chris K
View shawnn's profile
shawnn
72 posts in 1268 days
#2 posted 10-15-2014 04:34 PM
It’s called 80/20. They have an outlet store on Ebay where the items you’re specifying for your design should be much more affordable than mill supply retailers.
shawnn
#3 posted 10-15-2014 04:36 PM
Oh yeah, I read a post on LJ here where someone used 80/20 to build a fence. It might be useful to find that post & read it.
UltramaticOrange
#4 posted 10-15-2014 04:40 PM
Awesome. Thanks, all! When I find that post I’ll link it here.
UltramaticOrange
#5 posted 10-15-2014 04:55 PM
Found it. It’s very nearly an identical design to the one in my head. Glad to see I’m on the right {pun omitted for content}.
http://lumberjocks.com/Hutch/blog/2740
View Mark Davisson's profile
Mark Davisson
597 posts in 3221 days
#6 posted 10-15-2014 04:57 PM
Allan Little is doing quite a lot with aluminum extrusions. He has some videos posted. Here’s the first:
https://www.youtube.com/watch?v=tN9tRwGJ0Xs&list=PLqtTuVwYBfkylRsdkaYoNuDIrdLOjEvym
-- I'm selfless because it feels so good!
UltramaticOrange
#7 posted 10-15-2014 05:51 PM
Allan Little is doing quite a lot with aluminum extrusions. He has some videos posted. Here s the first:
- Mark Davisson
Thanks! I’ll check it out when I get home.
