Finish / Seal Crosscut sled
Forum topic by kmerkle posted 10-14-2014 04:31 PM 979 views 0 times favorited 6 replies Add to Favorites Watch
View kmerkle's profile
kmerkle
33 posts in 2242 days
10-14-2014 04:31 PM
Topic tags/keywords: sealer humidity finishing
I made a crosscut sled from 1/2” baltic birch plywood with with oak runners. It worked great when I made it, which happened to be in the Spring when the humidity in SC is moderate. However, my shop is in my garage and my sled swells with the humidity and becomes nearly unusable.
I’m planning to set it out in the sun this Fall on a nice cool day, let it shrink back to original size, and then seal it with something that will hopefully prevent it from absorbing moisture and swelling when it becomes humid again.
My question is, what is the best thing to seal it with? Shellac? Polyurethane?
Thanks!
Kurt
-- Every project is perfect until it's started.
View Bill White's profile
Bill White
4861 posts in 3868 days
#1 posted 10-14-2014 04:39 PM
Put some shellac on it. Let it dry, then wax it.
Bill
-- bill@magraphics.us
View bondogaposis's profile
bondogaposis
4611 posts in 2259 days
#2 posted 10-14-2014 05:43 PM
If that doesn’t work you may want to replace the runners w/ something stable like aluminum or composite. A finish will slow the reaction to humidity but not stop it.
-- Bondo Gaposis
View ChefHDAN's profile
ChefHDAN
1010 posts in 2757 days
#3 posted 10-14-2014 07:13 PM
I use wipe on poly and wax, for runners I have corian counter top scraps which work really great for the runners, and you can machine it easily just like it’s wood, wear a mask though cause it really stinks.
Rick Dennington
5698 posts in 3102 days
#4 posted 10-14-2014 07:40 PM
A 50/ 50 mix of tung oil and mineral spirits…..I use it on all my sleds…..
View Mainiac Matt 's profile
Mainiac Matt
7671 posts in 2236 days
#5 posted 10-14-2014 07:45 PM
I’ve had good luck with both UHMW runners (cut oversize and hand planed to a snug fitting width) as well as with extruded AL T-track.
-- Pine is fine, but Oak's no joke!
kmerkle
#6 posted 10-14-2014 07:46 PM
Thanks guys!
