Drill bit sharpening
Forum topic by rantingrich posted 10-13-2014 07:42 PM 1053 views 0 times favorited 6 replies Add to Favorites Watch
View rantingrich's profile
rantingrich
372 posts in 1467 days
10-13-2014 07:42 PM
Can anyone recommend a Drill bit sharpener! Has anyone been happy with that thing they sell at lowes called the Drill Bit Doctor?
-- Rich
MrUnix
6894 posts in 2320 days
#1 posted 10-13-2014 08:19 PM
This is all I use.. works great and has multiple uses :)
View Mainiac Matt 's profile
Mainiac Matt
8355 posts in 2450 days
#2 posted 10-13-2014 08:25 PM
I’ve seen the Drill Doctor in use and it seems like a nifty set up.
The key is getting the angles uniform, and that’s exactly what they Drill Doctor does well.
I’ve wanted one for a long time, but their quite pricey.
-- I yam what I yam and that's all what I yam
View robscastle's profile
robscastle
5256 posts in 2326 days
#3 posted 10-13-2014 08:30 PM
I have a drill doctor 360 it sharpens bits to 1/2 or 13mm.
It works well but requires precice setting up as it tends to change the angle of the chisel points.
I took up the question of the chisel point changing with Drill doctor and they explained the setup to me again.
I found if the chisel point does change the only way to get it back was to grind the tip off flat, and start again.
Otherwise ita a reasonable low end entry point for drill sharpening.
Originally it was up around $360 AUS but has since seen a dramatic drop in price, like 50%
I wouldnt rave about it but it does the job, keeping in mind how many drill sets you could buy for the price of it.
-- Regards Rob
View waho6o9's profile
waho6o9
8364 posts in 2698 days
#4 posted 10-13-2014 08:51 PM
View gfadvm's profile
gfadvm
14940 posts in 2812 days
#5 posted 10-14-2014 12:23 AM
I like my Drill Dr for my twist bits (quick and easy).
But it won’t sharpen brad point, spade, or Forstner bits.
View KevinL's profile
KevinL
33 posts in 1472 days
#6 posted 10-14-2014 12:40 AM
I use a Black Diamond at work as a toolmaker but have found the Drill Doc works just as good at home. It is a little more fussy setting up, but it does give great results on jobber drill bits.
-- KevinL
