Forum topic by Deela40 | posted 10-12-2014 11:40 PM | 1759 views | 0 times favorited | 12 replies | ![]() |
Topic tags/keywords: ash router chip shaping question I am trying to use my router with Ash, but am having an issue. As you can see in the image below, the router is chipping away some of the lumber. The one on the left is how it should look, but the one on the right is how most of them turned out. The bits are new and I am using a SKIL 1-3/4 HP router. Any ideas as to why this would happen? -- www.heritageclothespins.com |
12 replies so far
#1 posted 10-13-2014 12:03 AM |
Some thoughts: take several shallow passes start routing from the other end of the board try a higher quality bit (Whiteside is my favorite) -- " I'll try to be nicer, if you'll try to be smarter" gfadvm |
#2 posted 10-13-2014 01:10 AM |
gfadvm, I actually took a couple of passes for the one on the left and it turned out pretty good, but I am trying to get a process down so I can mass produce something so I’m attempting to cut out as many steps as possible. -- www.heritageclothespins.com |
#3 posted 10-13-2014 01:17 AM |
My guess, grain orientation is causing tearout- change the direction of feed. You can see where the router blade would just love to chunk out the open grain on those ridges. What are you fluting the face of the boards, anyway ? |
#4 posted 10-13-2014 01:40 AM |
BLarge, Thanks for the suggestion. I am making clothespins. As a result, I need to go across the grain in order to come out with stronger pins. -- www.heritageclothespins.com |
#5 posted 10-13-2014 01:45 AM |
I would NEVER have guessed clothespins!!! -- " I'll try to be nicer, if you'll try to be smarter" gfadvm |
#6 posted 10-13-2014 01:49 AM |
It’s hard to find quality clothespins these days so I’m making my own. -- www.heritageclothespins.com |
#7 posted 10-13-2014 01:57 AM |
You are correct about quality clothes pins. Actually, you have to make your own to get quality in about anything. I bought a router bit for making dados in some plywood. It was a Bosch and I thought it would be a decent bit but it chipped and burned from the beginning. I ordered another bit from Rockler and it was great. I am not promoting Rockler but I am saying I really thought the Bosch would have been as good if not better but not so. Always take your cuts just like you read. Left to right . watch your speed and get that adjusted. Select the right boards for the project. |
#8 posted 10-13-2014 02:06 AM |
Grandpa, Thanks for the advice. I will look at another source for bits to see if a change would help. I initially tried walnut to get the process down since I had some on hand. It turned out a little better, but I still had some of the same results. I prefer ash since it does not have tannin in it. Maple is another option that does not have tannin, but it is more expensive. If I used another type of wood, it could result in stained clothes. -- www.heritageclothespins.com |
#9 posted 10-13-2014 02:17 AM |
You are correct. stains would be good. What about beech? |
#10 posted 10-13-2014 02:37 AM |
Do you have the speed set as fast as possible? -- Bill M. "People change, walnut doesn't" by Gene. |
#11 posted 10-13-2014 03:22 AM |
Maybe try a different wood. Any of the ring porous hardwoods are going to be prone to chip out. I think you wood get better results w/ birch. -- Bondo Gaposis |
#12 posted 10-13-2014 03:23 PM |
1/4”shank router bits vibrate a lot more than 1/2” shank ,if your using 1/4” shank and can switch try that,if not I agree with taking several shallow passes. -- https://www.artisticwoodstudio.com/videos wood crafting & woodworking classes |
Forum | Topics |
Woodworking Skill Share
12028 |
Woodturning
2106 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4904 |
6694 |
28052 |
CNC Woodworking
211 |
Hand Tools
5407 |
Jigs & Fixtures
1417 |
Wood & Lumber
6232 |
1388 |
Focus on the Workspace
2154 |
1186 |
Woodworking Trade & Swap
4754 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8845 |
