Forum topic by siggs | posted 10-11-2014 02:39 AM | 1212 views | 0 times favorited | 6 replies | ![]() |
I’m working on a beast table with fir been try to figure out a strong functional and relatively easy way to mount the top. This is what i came up with inexpensive but it took a couple hours to make the brackets from pre cut 1/8 metal painfully on the drill press and dremel, then to route and fit. I don’t mind using a bit metal and bolts i have to keep the time down to sell competitivly. |
#1 posted 10-11-2014 04:34 AM |
Looks like it should work. I really like your table design…very cool looking. |
#2 posted 10-11-2014 08:12 PM |
Considering the apparent weight of the trestles are those 1/8” brackets strong enough to hold everything together when you attempt to lift the table by its top? That is my only concern, otherwise, looking very massive and good indeed! -- "I never met a board I didn't like!" |
#3 posted 10-11-2014 08:38 PM |
I guess we will find out shortly, they seem very rigid i also have some 1/4” just incase as well as the ability to add more 1/8” . I have seen others similar at restoration hardware but seesh they just scew the top in from underneath the tresstle. Crossed fingers anyways thanks. |
#4 posted 10-11-2014 08:48 PM |
Looks like it should work fine the metal is even slotted to allow for wood movement . -- https://www.artisticwoodstudio.com/videos wood crafting & woodworking classes |
#5 posted 10-12-2014 01:48 AM |
It worked out just great, minimal movement and lifting it caused little flex. Mind you it’s wide at 40” so the whole thing was designed to come apart for moving any distance. Moving a few inches here or there not a prob with the top on. A good learning experience for me. Doing loose tennons with the router sucked for the bread board ends. It was difficult and time consuming, couldn’t justify a domino and couldn’t flip it over alone to do traditional methods. If i could come up with a way to make it faux 2” that would be cool. Might even consider tng or half lap for the planks and forget the ends for a more production piece. Until i get a faster method. |
#6 posted 10-12-2014 02:13 AM |
Damn, nice looking table. |
Forum | Topics |
Woodworking Skill Share
12028 |
Woodturning
2106 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4904 |
6694 |
28053 |
CNC Woodworking
211 |
Hand Tools
5407 |
Jigs & Fixtures
1417 |
Wood & Lumber
6232 |
1388 |
Focus on the Workspace
2154 |
1186 |
Woodworking Trade & Swap
4755 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8845 |
