Table saw motor advice
Forum topic by GarageBoy posted 10-11-2014 12:30 AM 1517 views 0 times favorited 22 replies Add to Favorites Watch
View GarageBoy's profile
GarageBoy
18 posts in 1566 days
10-11-2014 12:30 AM
The motor on my table saw died and can get a motor that I think will work. It’s brand new, but made for an Evaporative cooler. Can i use that to replace it?
22 replies so far
View MrUnix's profile
MrUnix
7114 posts in 2440 days
#1 posted 10-11-2014 01:53 AM
Whats wrong with the one on the saw now? Could be just a simple fix.
View pintodeluxe's profile
pintodeluxe
5819 posts in 3054 days
#2 posted 10-11-2014 01:57 AM
Did you check the overload trip on your tablesaw motor?
Here’s hoping you don’t have to replace the motor.
View bigblockyeti's profile
bigblockyeti
5319 posts in 1961 days
#3 posted 10-11-2014 02:18 AM
You might be able to use it, but how long it will last might be another story.
View realcowtown_eric's profile
realcowtown_eric
617 posts in 2178 days
#4 posted 10-11-2014 03:40 AM
If it’s an “open” motor, might be a good idea to blow the sucker out with compressed air.
If that doesn’t work, pull it apart and take a points file to the starting points…over years they can get gummed up with fine dust and the arcing as they engage and disengage generates crud on the points.
or take it into a motor rewinder for a tune up. They’ll likely send you down the path of my next suggestion once you tell them the application.
After you’ve done all that, and maybe get it working, look for an enclosed motor. There’s a reason that folks use them on woodbutchery machinery. They are a tad more expensive
-- Real_cowtown_eric
View TheFridge's profile
TheFridge
10818 posts in 1727 days
#5 posted 10-11-2014 03:54 AM
If it didn’t smoke or it just hums, there is a good chance it’s fixable.
Not really sure about a compressor motor.
GarageBoy
#6 posted 10-11-2014 05:09 AM
It Humms for a few seconds and then trips the breaker. I did a lot of research and the first clues led me to think it was the Capacito, so i replaced it, which didn’t work. Then i came to believe that it may be the bearing’s so I lubed them up godd and had them spinning pretty smoothly. I cleaned it out of cobwebs, dust, etc… at that time too. Lastly, I thought it might be the on and off switch (previous owner had swithed it out with a standard light switch like uou may have to turn your lights on your wall). It looked good, just had some sawdust in their which I also cleaned out. All this to no avail, as it is still doing the same thing which leads me to where I am today.
GarageBoy
#7 posted 10-11-2014 05:11 AM
Also, my current one does not have a reset button
TopamaxSurvivor
18428 posts in 3917 days
#8 posted 10-11-2014 05:34 AM
Might be the start switch. Give it a spin if you can and see if it goes.
View pauljuilleret's profile
pauljuilleret
106 posts in 1893 days
#9 posted 10-11-2014 10:24 AM
Swamp cooler motors rely on the air they pull through the cooler for cooling it’s self they do not have a cooling fan built into it like other motors do. I think it would overheat and also quit working in a short time. yes if you look I’m in Ohio and coolers like that are not used here as it’s already to humid bit I liven in Phoenix for many years and they still use them out there I think if it were me I would find a motor hospital and put it in there to be checked out could be a cheep fix or they could find a direct replacement for it. good luck, Paul
View mahdee's profile
mahdee
4045 posts in 2008 days
#10 posted 10-11-2014 11:43 AM
Most electric shops can rebuild it for you.
-- earthartandfoods.com
TheFridge
#11 posted 10-11-2014 12:00 PM
Yup. May have a bad centrifigal switch. Humming is a lot better than no humming or it was smoking.
5242 posts in 2734 days
#12 posted 10-11-2014 12:21 PM
I would caution you against using the swamp cooler motor for the TS. Like many others, I’m guessing the problem with yours is very simple (I think you’ve blown a capacitor). Those are extremely easy to check, there should be some humps (or hump) on the motor (maybe a box), loosen one up and smell, then look for an oily substance around the innards. Either (and both) mean you have a bad cap. they run anywhere from $8-$20 or so. Go to an industrial supply, electrical supply, or motor shop and get another one.
GarageBoy
#13 posted 10-11-2014 01:26 PM
Thanks for the advice guys. Fred, already switched the Capacitor, but that did not work. I think I’m gong to take it in to the “motor hospital” as paul suggested. Thanks again to all.
View timbertailor's profile
timbertailor
1594 posts in 1665 days
#14 posted 10-11-2014 02:19 PM
If the motor is toast, look for a TEFC motor from Baldor. A Lesson if the Baldor is out of your budget.
realcowtown_eric
#15 posted 10-12-2014 02:49 AM
Them motors actually do require smoke to operate.
Once the smoke escapes, they don work no more.
Just like most other electrical appliances….
Eric
(ducking and running)
