separator for dust collector
Forum topic by Mark posted 10-10-2014 01:12 AM 2816 views 1 time favorited 17 replies Add to Favorites Watch
View Mark's profile
Mark
6 posts in 1562 days
10-10-2014 01:12 AM
Topic tags/keywords: jig question
Well it’s time for a dust collector, I have waited long enough. I recently bought a harbor freight two horsepower single stage dust collector. I want to add a Thein separator on it. I have been searching for a plan all over the webonet and have seen many descriptions but no complete sets of drawings. I’m having no luck finding anything that I can build from. If anyone can point me to the tophat design they used I would greatly appreciate it.
-- Mark, Greenville, SC
17 replies so far
View English's profile
English
660 posts in 1714 days
#1 posted 10-10-2014 01:47 AM
Try this link. Gives all the dimensions letting you chose your can. http://www.jpthien.com/cy.htm
By the way. I lived in Mauldin for 29 years moved four years back. I love the area.
-- John, Suffolk Virgina
English
#2 posted 10-10-2014 02:23 AM
Try This one, looks like they give dimensions for most items over the 12 pages. http://www.jpthien.com/smf/index.php?topic=563.0
View timbertailor's profile
timbertailor
1594 posts in 1661 days
#3 posted 10-10-2014 02:31 AM
Here is my take on the Central Machinery unit and addresses most of the shortcomings found in its original offering.
It uses the Thien Cyclone, as outlined in the links above.
View Scott C.'s profile
Scott C.
160 posts in 2288 days
#4 posted 10-10-2014 02:42 AM
I have that DC with a wynn filter and cleaned out the inside of the filter for the first time the other day. I was shocked at how clogged it was. After cleaning it, the difference in suction was substantial so a seperator is a must in my opinion. I made a thein baffle for the DC’s ring, not sure how well it’s working yet, but it was a quick first step and will hopefully help.
-- measure twice, cut once, swear and start over.
View Mark's profile
Mark
#5 posted 10-10-2014 12:05 PM
Thanks to everyone for the suggestions. I believe the configuration I will be using will be similar to TIMBERTAILOR’s cart design but utilizing a tophat separator.
timbertailor, I am Not sure how you collect the remaining dust that drops below the below the Filter?
timbertailor
#6 posted 10-10-2014 02:00 PM
Thanks to everyone for the suggestions. I believe the configuration I will be using will be similar to TIMBERTAILOR s cart design but utilizing a tophat separator.
- Mark
I just pull the filter and housing as a unit. I can clean the filter at the same time. It is just held in place with three wood blocks, screwed to the plywood and sitting in a bead of silicone. I did cut a groove, as seen in the last photo, in the rim of the plywood for the housing to sit in.
I am glad you like the design. The last photo is the dust collection area after I had run 10 Lbs of dust through the unit. As you can see from the photo, there is only a slight film of fine dust after all that material was sucked up.
View ducky911's profile
ducky911
237 posts in 3026 days
#7 posted 10-10-2014 05:20 PM
If it was me I would opt for a super dust deputy or super dust deputy xl . $169 totally worth it.
http://www.oneida-air.com/inventoryD.asp?item_no=SCOLLECT43&CatId={17F46883-40BB-471E-982F-E5F28583241B}
I think you would get better air flow. The 40% loss in CFM’s from a thien is a tough one.
View Mark's profile
Mark
#8 posted 10-13-2014 01:34 PM
Is that 40% loss in CFM’s from the Thien top hat a realistic number? What is the loss from the dust deputy? I have some heavy duty machines that I will be using this on that create a lot of chips (see photo’s). I tried my 20” SCMI industrial planer with the Harbor Freight 2hp collector in the factory setup and it will clear the chips and it is the biggest waste generator that I have. The Oliver dual head shaper shown also make some serious chips. But not sure if any of them will work if I lose 40% just by adding the separator.
View TheDane's profile
TheDane
5575 posts in 3900 days
#9 posted 10-13-2014 02:03 PM
I don’t have empirical data on CFM loss with the Thien baffle or cyclones, but there is certainly some. That being said, IMHO the advantages of a separator outweigh the downsides. Here is the rig I am using:
HillbillyShooter
5811 posts in 2529 days
#10 posted 10-13-2014 02:13 PM
Here’s a link to the plans I used to build my Thein separator: http://www.freeforum101.com/charlesneil/viewtopic.php?p=11836&mforum=charlesneil#11836
I felt like these were great plans, with easy to follow instructions. There hasn’t been any noticable accumulation in the DC bags since I put it into operation last winter, and I’ve empied the can at least 10-times. There is a loss in vacuum CFM, but I sure don’t think it has been more than 20%. At least, the can now fills withput flowing through to the DC bag. BTW, here is the link to my Thein project: http://lumberjocks.com/projects/102418
ducky911
#11 posted 10-13-2014 03:38 PM
40% yes…I tested mine with a wind gauge I bought on amazon.
I had read several posts on the Thien board about losses from 38% and up. I did not beleave it. So I built one. Its laying in the yard now…free if someone wants it.
I do not know what the loss would be for the dust deputy but I bet it is not 40%.
5234 posts in 2730 days
#12 posted 10-13-2014 03:45 PM
All separators cause a loss of air flow, the nature of the beast. I have no idea how much each of the 2 in question cause, but I can tell you that not long ago a magazine (FWW, I think) tested them and you might want to look at that article. I know the Thein came out very well in that test, presumably they had some science in their efforts. But if you just have a 4” duct to the machines, it may not matter. About the most you can pull through that would be on the order of 400 CFM or so, and I suspect that DC will do 400 CFM with any of the separators.
View CharlesA's profile
CharlesA
3358 posts in 2034 days
#13 posted 10-13-2014 03:46 PM
wow on the 40%. I put together the very basic separator (looks like the one below), with no cyclone or baffle. I haven’t checked airflow. I wonder how efficient it is.
View Mark's profile
Mark
#14 posted 10-14-2014 12:22 PM
The Freedom Forum 101 webpage is not available. It seems to be down or removed for some reason.
Thank you all for the input. Whichever way I go dust deputy or Thein (still not decided), I will need to have at least a 5” or 6” main line comming out of the HF 2hp collector and going directly to the bigger machines. Any thoughts on reasonably priced ducting that fits this collector witout much modification?
TheDane
#15 posted 10-14-2014 01:50 PM
... I will need to have at least a 5” or 6” main line comming out of the HF 2hp collector and going directly to the bigger machines.
Whether you choose a baffle or a cyclone, your dust collector needs to attach to the outlet of the baffle or cyclone. The machines attach to the input of the baffle or cyclone.
In my case, the SDD’s output is 6-inch and mys dust collector’s input is 4-inch, so I ordered the 6” to 4” reducer from Oneida when I ordered the cyclone.
