Band saw info?
Forum topic by MissouriOutdoors88 posted 10-09-2014 11:48 PM 1446 views 0 times favorited 33 replies Add to Favorites Watch
View MissouriOutdoors88's profile
MissouriOutdoors88
334 posts in 1300 days
10-09-2014 11:48 PM
Anyone know anything about this brand of band saw? Can’t find much info online.
-- I'm an aspiring woodworker with a degree in Biology.
33 replies so far
View TheFridge's profile
TheFridge
9249 posts in 1448 days
#1 posted 10-10-2014 12:02 AM
No. But I have some chisels and forstner bit made by them. I think it’s the equivalent of harbor freight. Maybe a lil but better.
MissouriOutdoors88
#2 posted 10-10-2014 12:03 AM
Are those tools good that you have?
View distrbd's profile
distrbd
2252 posts in 2408 days
#3 posted 10-10-2014 12:05 AM
This all I could find:
The Professional Woodworker brand produced under trademark since 2009 by Homier Distributing Corp:
-- Ken from Ontario, Canada
View MrUnix's profile
MrUnix
6574 posts in 2161 days
#4 posted 10-10-2014 01:13 AM
Generic import:
The same model number (BPVBS14) as Harbor Freight, Buffalo and others.
MissouriOutdoors88
#5 posted 10-10-2014 01:56 AM
So is it junk lol?
TheFridge
#6 posted 10-10-2014 02:01 AM
Depends. My stuff is ok but that’s about it.
MissouriOutdoors88
#7 posted 10-10-2014 02:03 AM
I really hope not.
17923 posts in 1818 days
#8 posted 10-10-2014 02:15 AM
It’s the same model as my old buffalo. Works for me. What are you hoping to do with it?
MissouriOutdoors88
#9 posted 10-10-2014 02:22 AM
Tell me if I’m crazy but I’m wanting to do
Some resawing/ripping with it. Be able to take some 4-6 inch cedars and essentially make some planks or square 4X4 type stuff with it. Is that doable?
#10 posted 10-10-2014 02:32 AM
You should be able to do that, slowly. I’ve resawn a 3 or 4” cherry log. I use a 1/4 blade. My 3/8 blade doesn’t cut as well as the 1/4.
MissouriOutdoors88
#11 posted 10-10-2014 02:36 AM
I’ll need a good fence/jig setup too won’t I? May need some advice on that. Maybe I can just build one.
MissouriOutdoors88
#12 posted 10-10-2014 02:37 AM
Also, even though it’s a 14 inch bandsaw, I can only cut 6 inches thick right? Why is it called a 14 inch saw?
View gfadvm's profile
gfadvm
14940 posts in 2652 days
#13 posted 10-10-2014 03:00 AM
I would scribe a line and follow it rather than trying to use a fence for a guide like a tablesaw as you will invariably have blade drift to deal with. Google “single point resaw fence” to see how I prefer to resaw.
14” bandsaws have wheels that are 14” in diameter.
MissouriOutdoors88
#14 posted 10-10-2014 03:06 AM
So bigger wheel translates to what then? More cutting power. Sorry for so many questions. I’ll run out soon enough haha.
gfadvm
#15 posted 10-10-2014 03:12 AM
Bigger wheels usually have more resaw capacity, cut faster, and fatigue the metal in the blades less as the band is turning a larger radius. Also most come with more HP. They also usually come with a larger table.
showing 1 through 15 of 33 replies
