Problems alligning Align-a-Rip Fence
Forum topic by alexjsd posted 10-09-2014 09:17 PM 1517 views 0 times favorited 6 replies Add to Favorites Watch
View alexjsd's profile
1 post in 1255 days
10-09-2014 09:17 PM
I have this old craftsman table saw with the align-a-rip fence. It seems to have alot of play left-right, so that even after using the 4 bolts to make parallel the fence, it still can move 1/4” out of parallel.
If i tighten the bolt at the outfeed end of the fence to the point of removing the play, then the fence is so tight that I can’t even make ANY adjustment to its position.
I included a few pictures to show what I mean. Any hints on solving this?...other than “go buy a new biesemeyer Fence”
View sawdustjunkie's profile
379 posts in 1646 days
#1 posted 10-09-2014 10:36 PM
Best thing I can suggest is if you have the money, go buy a better fence. I just sold my Craftsman today and I had installed a Muel Cab Accufence on it and never had another problem with alignment issues.
There are several available that just bolt right on the Craftsman.
-- Steve: Franklin, WI
View TheFridge's profile (online now)
9052 posts in 1415 days
#2 posted 10-09-2014 10:56 PM
Had an align a rip. There is nothing you can do to improve it. I’ve tried.
I bought a $144 saw stop tsa-pfa fence from i think.
2691 posts in 1954 days
#3 posted 10-10-2014 07:25 AM
Any kind of T-square fence is better than a fence that has to grip the far side of the table to be stable.
18224 posts in 3605 days
#4 posted 10-10-2014 09:02 AM
That is what I did, replace the fence that grips the far side of the table with a T-square fence. Just got tired of checking square every time it was loosened and then still not having it square when it was tightened!
View Targa's profile
118 posts in 1669 days
#5 posted 10-10-2014 09:11 PM
I have a Align-a-Rip Fence that I bought used as a low cost upgrade for the terrible fence that came on my craftsman 113 saw.
I did have to fiddle with it to dial it in and get it to glide smoothly and lock tightly but it works pretty well.
One adjustment I had to make to get my fence to work properly was to shim the front and rear rails slightly to make them parallel to each other. Then I adjusted the fence to be parallel with the blade. That may be something you need to do as well.
I can’t imagine how you can move the fence a 1/4” out of parallel if the 4 bolts on the top and bottom are tight? Is that with the handle in the locked down position?
-- Dom
View Stew81's profile
34 posts in 1295 days
#6 posted 10-10-2014 09:26 PM
I had an Exact-I-Rip Fence on my Craftsman 113 (Very Similar to the Align-a-rip). I’d agree with Targa, I think you need to level and shim your fence rails so they are parallel. Then square the fence to the blade, lock the fence down and tighten the nut at the out feed side until the fence doesn’t move anymore.
-- Stew
