drywall 2 car garage ceiling: type-x or type-c ?
Forum topic by Holbs posted 10-09-2014 12:31 AM 1567 views 0 times favorited 6 replies Add to Favorites Watch
View Holbs's profile
Holbs
1878 posts in 2052 days
10-09-2014 12:31 AM
The original ceiling was 5/8” 4’x8’ gypsum type-x fire rated drywall, 15 boards. I removed all of it due to wanting to insulated, run wires, and too many damaged areas. I’m ready to re-install before snow starts a coming. Someone mentioned the new stuff called type-C: better fire rating at 1/2” than the fire-x at 5/8” by far, 3% lighter (whoopie do), and stronger (due to more fibers). So now I’m undecided to go with the original 5/8” type-x or newer 1/2” type-c. I can only get 4’x12’ in the type-c for $16 a sheet, not 4’x8’. That means less taping & mudding, less screws. I’ll be using a drywall lift either way, so physically installation does not matter between the 2.
Anyone know of pro’s and con’s between 5/8” 4’x8’ type-x and 1/2” 4’x12’ type-c ?
oh… and this is not from Home Depot but AMS chain. Delivery is just $60 vs HD $100.
-- The Carpenter Bee is derived from the Ancient Greek word wood-cutter
View jmartel's profile
jmartel
7951 posts in 2172 days
#1 posted 10-09-2014 12:34 AM
What’s the cost per square foot of each? And do you know if code in your area specifies a minimum thickness or just a minimum fire rating? A 4×12 will be more difficult to move around since it’s 50% more weight than a 4×8, something to consider.
Holbs
#2 posted 10-09-2014 12:36 AM
J.. I just started today after visiting AMS. I have to call the county code office to ask them that question of minimum thickness (tho, i would imagine long lasting drywall would outweigh thickness?).
I do not see an issue of weight since using a drywall lift. never used one before, so could be wrong.
The 4’x8’ 5/8” type-x was $10.50, 4’x12’ type-c at $17.50 i believe. Was driving on speakerphone when he told me cost per square foot so did not exactly pay attention to that detail :)
Holbs
#3 posted 10-09-2014 12:51 AM
1. The garage shall be separated from the residence and its’ attic area by not less than 1/2-inch gypsum board applied to the
garage side. Garages beneath habitable rooms shall be separated from all habitable rooms above by not less than 5/8-inch
Type X gypsum board or equivalent. Where the separation is a floor-ceiling assembly, the structure supporting the separation
shall also be protected by not less than 1/2-inch gypsum board or equivalent. Doors to be 1 3/8” solid core or rated 20 min
good ‘ol google. I will still call the building dept to ask about type-c.
View JoeinGa's profile
JoeinGa
7736 posts in 2029 days
#4 posted 10-09-2014 12:13 PM
Lighter, less screws, less tape and mudding. And since you’re using a drywall lift (what a lifesaver those things are) I’d go with the 1/2” for all the reasons you stated.
PROVIDING your codes will allow it.
View Grandpa's profile
Grandpa
3259 posts in 2698 days
#5 posted 10-09-2014 02:50 PM
As stated it depends on the local codes. Sometimes there are codes that say 5/8 and it doesn’t matter that the 1/2 inch is better and will last longer.
Holbs
#6 posted 10-09-2014 11:48 PM
Called the county building code folks. It can be type-c 1/2” as long as no habitat above, else it would have to be 5/8”. Now to play tetris and fit 4’x12’ sheet….
