Difficult feeding on table saw
Forum topic by mortalwombat posted 10-08-2014 08:06 PM 1268 views 0 times favorited 13 replies Add to Favorites Watch
View mortalwombat's profile
mortalwombat
65 posts in 2115 days
10-08-2014 08:06 PM
Topic tags/keywords: table saw feeding buildup polystyrene ripping smooth smoothley
I haven’t had my table saw too long now, and lately I have noticed the saw being a little difficult to feed, especially when ripping. I have noticed a bit of buildup on the blade insert. I’m not exactly sure what it is. Maybe sap, or maybe paint? I used the saw to cut some polystyrene base moulding, so maybe it’s residue from that?
Either way, I’d like to clean this buildup off the saw. There’s also some buildup on the blade that I am certain is from that polystyrene. What is the recommended method for cleaning? Are there any recommendations for keeping things moving smoothly in general?
13 replies so far
View mahdee's profile
mahdee
3873 posts in 1735 days
#1 posted 10-08-2014 08:15 PM
Soak it in diesel overnight and brush it clean. Wash with dish soap.
-- earthartandfoods.com
mahdee
#2 posted 10-08-2014 08:17 PM
mahdee
#3 posted 10-08-2014 08:23 PM
Soak in diesel overnight, brush clean and was with dish soap.
mahdee
#4 posted 10-08-2014 08:29 PM
hmmm, triple post.
View Fettler's profile
Fettler
200 posts in 1965 days
#5 posted 10-08-2014 08:42 PM
Check that your fence is square to the blade. Binding from the blade would be might first thought. On my Unisaw i use a coat of renaissance wax to protect the top and help things glide better.
That build up is likely gum/resin/pitch and can be removed with bit/blade cleaner. I can’t remember what brand i use, maybe this one:
http://www.woodcraft.com/Product/128479/Blade-and-Bit-Cleaner-8-Ounce-Pump-Spray.aspx
-- --Rob, Seattle, WA
View OhioMike's profile
OhioMike
79 posts in 2130 days
#6 posted 10-08-2014 08:46 PM
I use Greased Lightning:
I place the blade on an old cookie sheet to contain the mess. I spray with Greased Lightning and let sit for a couple minutes. I then scrub the teeth with a brass brush but an old toothbrush would likely work almost as well.
Rinse with water then dry completely and you’re done.
Mike
View pintodeluxe's profile
pintodeluxe
5623 posts in 2781 days
#7 posted 10-08-2014 08:53 PM
What kind of blade? Perhaps a new Diablo Thin Kerf would solve your problem.
I have had plastic that wouldn’t come off tablesaw blades. For typical cleaning of pitch and resin I use Simple Green purple.
17961 posts in 1824 days
#8 posted 10-08-2014 08:57 PM
+3 to what mrjinx said.
mortalwombat
#9 posted 10-08-2014 09:37 PM
Diesel sounds like a great plan. I’ll try that and check how square the saw is. I squared it up the best I could when I first got the saw last year, but I didn’t have the most accurate measuring tools to do it so it may not have been perfectly square. It’s probably a good time to recheck everything and re-lube it all while I’m at it.
Thanks!
View knotscott's profile
knotscott
7980 posts in 3343 days
#10 posted 10-08-2014 10:19 PM
Rinse with water then dry completely and you re done.
Mike
- OhioMike
I use a similar method with Greased Lightning, or 409, or Fantastic, or LA’s Totally Awesome….whatever’s around tends to work. The important step is to clean them. For really grungy blades, Freud suggests kerosene because it’s pH neutral.
View dhazelton's profile
dhazelton
2756 posts in 2264 days
#11 posted 10-08-2014 11:54 PM
Does it feed easier and cut better when you raise your blade?
View buildingmonkey's profile
buildingmonkey
242 posts in 1515 days
#12 posted 10-09-2014 12:54 AM
For the pitch buildup, the spray bit and blade spray cleaner Grizzly sellls cleans very quick. I spray it on my cutters on the jointer and planer and use a toothbrush to scrub. don’t have to wait but a few seconds before swcrubbing, much quicker than Rockler’s cleaner. You have to wait a LONG time for that stuff to work.
-- Jim from Kansas
knotscott
#13 posted 10-09-2014 10:49 AM
If the blade has been dirty for a while, it may be prematurely dull as a result. Cleaning is always a good idea, but you may want to consider sharpening or replacement depending on how good of a blade it is.
