Electric motor connection diagram
Forum topic by brucenjen posted 10-08-2014 02:31 PM 1174 views 0 times favorited 5 replies Add to Favorites Watch
View brucenjen's profile
6 posts in 1258 days
10-08-2014 02:31 PM
Topic tags/keywords: bandsaw jointer plane question resource electrical motor
I have a 1 ½ hp, 4 pole single phase, 1720 rpm, 115/230 volt motor. I am attempting to wire the motor for 115 volt. I set the continuity tester on 2,000 ohms. When the leads were placed together the reading was 0.
The attached pic is the plate on the motor.
Readings between the following wires.
Black White 1 Red Yellow 1 2 Grey = capacitor
White Red 1 Black Red 0
White Yellow 0 Black Yellow 1
Assuming that:
Black 1, White 2, Red 3, Yellow 4
This may reflect the correct wiring on that motor’s plate, but what about the capacitor?
L1 L2
1-3 2-4
Black Red White Yellow
What do I do with the capacitor? The motor has three placed to connect wires:
1 3 2-4
Grey Grey
Ok? If the motor needs to be reversed:
1-3 4 2
Black Red Yellow White Grey Grey
Any help would be appreciated.
Should perk up the bandsaw.
5 replies so far
View dozer57's profile
92 posts in 1431 days
#1 posted 10-08-2014 02:40 PM
Bruce your on the right track, wire it as the diagram shows. The gray wires are the starting winding with a cap for extra tork for start up. put one gray wire one each line.
View REO's profile
928 posts in 2005 days
#2 posted 10-09-2014 01:28 AM
provide a picture of the connection area.
#3 posted 10-09-2014 02:35 AM
Here it is with: Line 1: black (1)/grey – red(3)/grey >>> White(2)-Yellow(4)
My numbers are based on my limited understanding of using a continuity tester.
View OldWrangler's profile
731 posts in 1526 days
#4 posted 10-09-2014 09:45 AM
This is how all my replacement motors have looked and you are right about the wiring. It’s not rocket science just standard 110/115 connecting. I think you have it figured out.
-- I am going to go stand outside so if anyone asks about me, tell them I'M OUTSTANDING!
#5 posted 10-09-2014 02:40 PM
Thanks for the help.
