slot dovetail method
« back to Joinery forum
Forum topic by CharlesA posted 10-07-2014 06:44 PM 1289 views 0 times favorited 11 replies Add to Favorites Watch
View CharlesA's profile
CharlesA
3305 posts in 1699 days
10-07-2014 06:44 PM
Topic tags/keywords: question joinery dovetail slot dovetail
I am cutting a double slot dovetail for the desk I am building. How would you cut the two recesses to accept the dovetails? These are large, so a router bit won’t work. I was thinking of using a forstner bit to cut away a majority of the waste and then chisel the remaining. Thoughts?
I’m using a Fine Woodworking plan that says “make the sockets.”
11 replies so far
View mds2's profile
mds2
310 posts in 1846 days
#1 posted 10-07-2014 06:53 PM
I’d use a dovetail saw and a chisel.
CharlesA
#2 posted 10-07-2014 07:00 PM
mds2,
So the dovetail saw would be for pretty minimal setting of the lines (at an angle), and the chisel for 90% of the work?
View pintodeluxe's profile (online now)
pintodeluxe
5565 posts in 2715 days
#3 posted 10-07-2014 07:03 PM
I wouldn’t be so quick to dismiss a router. I have had good luck routing dovetail sockets with a 1/4” spiral bit. The big advantage with a router is the bottom of the cut will be uniform. Cut close to the line, and pare the rest with a sharp chisel.
http://lumberjocks.com/pintodeluxe/blog/38791
CharlesA
#4 posted 10-07-2014 07:17 PM
Willie, I hadn’t thought of using a straight bit, just not a dovetail bit. Good thought.
View jmartel's profile
jmartel
7687 posts in 2052 days
#5 posted 10-07-2014 07:37 PM
One thing that you can do is to chisel out the very top of the dovetail socket, say 1/8” deep. Make sure it the dovetail fits it nicely. Then you come back with a router with a pattern bit, and set it up so that the bearing rides on the area you have just chiseled out.
View mds2's profile
mds2
#6 posted 10-07-2014 07:49 PM
mds2,
- CharlesA
Yes, exactly. You are essentially making a half-blind dovetail, correct? Or am I mistaken?
View timbertailor's profile
timbertailor
1594 posts in 1326 days
#7 posted 10-07-2014 07:50 PM
I second the use of a 1/4” down cut spiral carbide bit.
View mds2's profile
mds2
#8 posted 10-07-2014 07:52 PM
View PaulJerome's profile
PaulJerome
57 posts in 2935 days
#9 posted 10-07-2014 08:19 PM
Do it with saw and chisel. You’d be surprised how fast it goes when chopping the waste. Just take your time when paring to the scribe lines.
-- Paul, Central Illinois
CharlesA
#10 posted 10-08-2014 03:42 PM
I watched the video, mds2. It’s pretty funny that his method he repented of in the first video is precisely the forstner method I thought I had dreamed up. I tried the dovetail saw/chisel method on a piece of scrap, and it worked just fine. I wouldn’t have thought of the multiple saw cuts.
I’ve only done half blind with a jig before, so this was kind of fun.
9931 posts in 3549 days
#11 posted 10-08-2014 04:12 PM
If doing more than a few, figuring out a way to waste
it out with a router after sawing what you can of the
edges may be worth the effort. If just doing a few,
excavating it all with chisels is not too onerous.
Good excuse to buy or make some skew chisels if
you don’t have a pair.
