router sled for end grain cutting boards- question
Forum topic by indychip posted 10-06-2014 10:52 PM 1152 views 0 times favorited 2 replies Add to Favorites Watch
View indychip's profile
indychip
79 posts in 2119 days
10-06-2014 10:52 PM
I have decided it is time to take the time and make a router sled to fix some of the cutting board issues that I have been having. Just a few questions for those of you who use this technique on end grain: What is the best router bit to use? Once the board is flat, do you use a ROS and what grit do you typicallly start with? I am trying to get away from the belt sander that I currently use, way to many issues. thanks
2 replies so far
View SASmith               's profile
SASmith
1850 posts in 2984 days
#1 posted 10-08-2014 09:28 PM
I have used this bowl bit and this bottom bit in the past. I would then use 80 grit on the ROS.
I now use a drum sander.
I think you will like the router sled much more than the belt sander.
-- Scott Smith, Southern Illinois
View Case101's profile
Case101
107 posts in 1790 days
#2 posted 10-08-2014 11:15 PM
Can you post a picture or a description of the router sled you’re talking about?
Thanks,
-- John, New Jersey
