Sliding Faux Barn Door
Forum topic by RJ2 posted 10-06-2014 07:22 PM 1968 views 0 times favorited 3 replies Add to Favorites Watch
View RJ2's profile
RJ2
151 posts in 3694 days
10-06-2014 07:22 PM
Topic tags/keywords: turning welding door lathe mahogany spline joint router ball bearing sliding door hardware arts and crafts rustic carving shaping turning lathe carving tool bandsaw drill press router tablesaw mahogany
Replacing my bi folds and Pocket doors with Faux Barn sliding rail type . Do it from scratch with the welded up2 X 3/8” steel rails and Turn the wooden ball bearing wheels fitted with Cam adjusting height axles attached to the plasma cut hanging strap iron (as you can imagine , this is where my wife came up with the model name perky , actually at first they were called.. TOO PERKY …). Pantry door was located just inside an arched opening and bi fold was always left open, and very annoying to swerve around constantly. Well we solved that problem . Now onto those PITA pocket doors .
-- RJ, Tampa Fl, RJMETALWOODS.COM
3 replies so far
View RJ2's profile
RJ2
#1 posted 10-06-2014 07:25 PM
I am working on a pulley wire system to make the doors work in conjunction . Probably going to make double track wood wheels where one door winds the other. Will involve making the wheels larger .
View RJ2's profile
RJ2
#2 posted 12-21-2014 04:16 PM
The wifey decided white was not the right color
View crank49's profile
crank49
4029 posts in 2879 days
#3 posted 12-21-2014 10:49 PM
good call
