| Forum topic by Beeguy | posted 291 days ago | 106 views | 0 times favorited | 3 replies | ![]() |
291 days ago |
I recently saw a video on building a coffee table using pocket screws. The project was oak and the top was a glued up (with screws) panel. The top was attached to the apron using screws. The dimensions were roughly 40” X 24”. My question is at what size panel do you have to consider wood movement and not attach it directly to the apron with screws? The top was made up of boards that looked to be three or four inches wide. I know wider boards have more movement. Is this the reason the screws were ok? If the top would have been made of three eight inch wide boards would that make using the screws a potential problem? -- Ron, Kutztown, PA "The reward is in the journey." |
