Jet Jointer takes off too much..?
Forum topic by joshtank posted 10-06-2014 05:15 PM 926 views 0 times favorited 12 replies Add to Favorites Watch
View joshtank's profile
joshtank
224 posts in 2969 days
10-06-2014 05:15 PM
It cuts nice and straight, but the in-feed table is as far up as it’ll go, and it’s is still taking too much of a bite. I can’t even bring the table to reach the ‘zero’ mark for depth. .
Thoughts?
-- Josh - Jacksonville, FL - https://www.youtube.com/channel/UC6eXmOxkM10zI0d-njOHeRQ
12 replies so far
View TheFridge's profile
TheFridge
9451 posts in 1482 days
#1 posted 10-06-2014 05:21 PM
Hand wheel? Lever?
View AlaskaGuy's profile
AlaskaGuy
4127 posts in 2305 days
#2 posted 10-06-2014 05:22 PM
How much is to much?
joshtank
#3 posted 10-06-2014 05:25 PM
hand wheel. I’ll take a measurement when I get home. I know i can’t get it to take light passes, like 1/16th of an inch.
4984 posts in 2489 days
#4 posted 10-06-2014 05:33 PM
Sounds like the knives aren’t down far enough.
18162 posts in 1853 days
#5 posted 10-06-2014 05:37 PM
I second Fred. The knives need to be adjusted.
View summerfi's profile
summerfi
3921 posts in 1683 days
#6 posted 10-06-2014 05:41 PM
Can you adjust the infeed and outfeed tables into the same plane by using a long straightedge? If so, then the knives are set improperly. If not, then something is messed up with the adjusting mechanism.
-- Bob, Missoula, MT -- Rocky Mountain Saw Works http://www.rmsaws.com/p/about-us.html
View BrianA's profile
BrianA
76 posts in 3025 days
#7 posted 10-06-2014 05:53 PM
Have you reached the end of the “0” on the depth of cut scale or is it just short of the 0? There is a lock out knob that will allow you to crank it up to the 0 on the depth of cut scale. At least there is on my Jet.
Brian
BrianA
#8 posted 10-06-2014 05:55 PM
Brian
View Hammerthumb's profile
Hammerthumb
2844 posts in 1971 days
#9 posted 10-06-2014 10:50 PM
Some Jet jointers have preset detent knob that needs to be pulled out while adjusting. Look for a little black knob on the back of the infeed table. Give it a pull while adjusting the infeed height. I think the first detent is at 1/16” so that may be where your stuck.
-- Paul, Las Vegas
View pintodeluxe's profile (online now)
pintodeluxe
5657 posts in 2809 days
#10 posted 10-06-2014 10:54 PM
Paul’s got it. Back the height adjustment down a little for a DEEPER cut, then release the black knob. It’s kind of like shifting into reverse when you parked on a steep hill. You gotta roll forward before you can get into reverse. The knob is actually supposed to set the maximum depth of cut at 1/8”, but I think the mechanism is stuck.
joshtank
#11 posted 10-07-2014 06:28 PM
YES. it was totally this back knob. thanks a ton!
Hammerthumb
#12 posted 10-07-2014 10:00 PM
You might want to check the bed alignment on infeed and outfeed now that you have figured out the problem. A little excessive adjustment with that black knob engaged can throw it out of alignment. Don’t ask me how I know this!
-- Paul, Las Vegas
