Disston Restoration
« back to Hand Tools forum
Forum topic by pstauffer82 posted 10-04-2014 09:02 PM 1268 views 0 times favorited 8 replies Add to Favorites Watch
View pstauffer82's profile
pstauffer82
8 posts in 1585 days
10-04-2014 09:02 PM
Topic tags/keywords: blade refurbishing traditional
Hello Saw Builders,
I picked up an 1880’s (about) Disston 14” backsaw on Ebay, when it arrived I was a little disappointed in the amount of pitting on the blade. I was wondering if anyone could tell me if this saw plate is worth saving? I’ve tried sanding with 80 grit, and using a coarse wire wheel, the pitting seems to be pretty deep. There’s no etch that I can see, so I didn’t feel bad trying to get agressvie.
On the plus side, the handle and back are in great condition, so even if the plate needs to be junked, or turned into a card scraper, I can experiment with making my own saw plate.
8 replies so far
View Bill White's profile
Bill White
5148 posts in 4197 days
#1 posted 10-04-2014 09:20 PM
I don’t see the plate being in that bad condition. Is it flat/straight?
I’m sure that it will need jointing and sharpening., Even at that, it should make a useable saw. Ya cut with the teeth, not the plate.
The tote is in remarkable shape considering the age. Thumbs up.
Bill
-- bill@magraphics.us
View chrisstef's profile
chrisstef
17798 posts in 3243 days
#2 posted 10-04-2014 09:23 PM
Kinda stinks that the little bit of pitting is at the tooth line. Id say it depends on what style you intend to use it as, rip or xcut. If its sharpened rip the pitting wouldnt be a huge deal. Sharpened xcut and it may be an issue. Its a good lookin saw, keep us up to date on the rehab.
View Don W's profile
Don W
19041 posts in 2804 days
#3 posted 10-04-2014 09:24 PM
I’d save it!
pstauffer82
#4 posted 10-05-2014 08:43 PM
Thanks guys, I think I’m going to go with making a new plate, I ordered a Shim Stock Strip, Blue Tempered Spring Steel, .020” Thick, 6” x 25” from www.mcmaster.com. I checked the old plate with my calipers, seems like that is the right thickness. I finished sanding the handle and put a light coat of BLO, and it looks great so far. I’ll keep the old saw plate for now and might try going after it again at a later date.
Don W
#5 posted 10-05-2014 09:10 PM
that’ll work to!
pstauffer82
#6 posted 10-20-2014 11:04 PM
So here it is, the finished product. Drilling the holes through the steel had to be the hardest part, even with a cobalt bit. Once I got that part done, the rest was too easy. I printed off a 10 PPI template and taped it to the saw plate. My hacksaw wasn’t doing the job cutting the notches, so I used my dremel with a diamond cutting wheel to -carefully- cut out a notch for each tooth that my saw file could fit into. An hour later, I had the teeth shaped, jointed, set and sharpened. It made some good test cuts on a piece of oak I had lying around, rip and crosscut.
View sikrap's profile
sikrap
1121 posts in 3595 days
#7 posted 10-22-2014 02:13 PM
Nice save!!!
-- Dave, Colonie, NY
chrisstef
#8 posted 10-22-2014 02:37 PM
Well done!
