MW radial arm saw router attachment
Forum topic by baysidebuz posted 02-07-2009 08:52 PM 8759 views 0 times favorited 6 replies Add to Favorites Watch
View baysidebuz's profile
baysidebuz
2 posts in 3427 days
02-07-2009 08:52 PM
I’m in need of the router attachment for my montgomery ward 10 inch radial arm saw. It is a simple piece that threads onto the 20K 15/32 diameter 20 tpi shaft and at the other end accepts a 1/4 inch router bit into its three jaw collet.
ToolKraft in Mass. does not carry this item. Any help with this request will be mosts appreciated.
thank you for your help,
Buz
View wood_wench's profile
wood_wench
89 posts in 3456 days
#1 posted 02-07-2009 08:57 PM
Have you checked out eBay or craigslist in the area?
View dalew's profile
dalew
1 post in 3420 days
#2 posted 02-07-2009 09:46 PM
I have an older Craftsman RAS and needed a chuck for horizontal boring. I found that Jacobs Multi-craft 1/2” chuck fit the accessory shaft on my RAS. Since it worked fine on drill bits, it shoudl work OK on router bits up to 1/2” Only problem using drill bits in this fashion is that the speed of the RAS is too fast and burns the wood.
-- Dale, Martinez, Ca
Dick, & Barb Cain
8693 posts in 4324 days
#3 posted 02-07-2009 11:37 PM
I recently bought an old Powercraft 10” Radial Arm saw to replace my burned out one.
So now I have an extra router collet from my old one.
Send me a PM if your interested.
View Brian024's profile
Brian024
358 posts in 3424 days
#4 posted 02-08-2009 01:29 AM
Bayside, I was checking through Ebay earlier for RAS accesories and a guy is selling a router bit attachment. Its a Craftsman which I’m not sure if it will fit yours or not.
http://cgi.ebay.com/Sears-CRAFTSMAN-Radial-Arm-Saw-Router-Bit-Adapter_W0QQitemZ140299185011QQcmdZViewItemQQptZRouters_Bits?hash=item140299185011&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A0%7C293%3A1%7C294%3A50
View OldButcher's profile
OldButcher
4 posts in 1224 days
#5 posted 02-13-2015 03:04 AM
A while back a fellow posted that a Porter Cable collet will fit. I have a similar issue in that I have the ¼” collet and want a ½” collet to fit the 15/32” – 20 thread spindle.
He said: I removed the chuck from a porter cable router and it fits perfectly on the 20,000 rpm arbor. I will try it out tonight and let you all know how it works but this gives me the option of 1/4 or 1/2 in router bits as well as 1/2 in arbors for shaper cutters. As for the 3500rpm arbor any drill chuck will fit.
I will try to acquire a Porter Cable collet/chuck to see if it fits. My next option is to see if a machinist can identify the thread pattern and fabricate one. ($$$$)
PS – I love this saw.
MrUnix
6766 posts in 2223 days
#6 posted 02-13-2015 03:23 AM
I’ve never done it on my RAS, but isn’t the spindle speed too slow for using as a router? What kind of operations are you guys doing with it?
